DA Groupset questions.
Wonderman
by Wonderman
Hi Guys,
I hope you can help I'm struggling finding definitive answers,
I'll explain what iv got atm and what I'm doing and hopefully it'll make sense.
At present I have ultegra 6700 with 50/34 praxis rings on a fsa crank and I'm buying a new groupset and cranks, but the groupset is coming tomorrow and the cranks will be a couple of weeks.
So this weekend I'm going to replace my shifters, mechs (rear short cage), cassette (with a 11-28) and chain (DA9000) but I will still have the 50/34 chainrings and cranks.
Then in a couple of weeks I will be fitting a 53/39 SiSL2 with spiderings.
My question is when the new chainrings arrive will the chain just swap over or will I have to get a new one to accommodate the larger chain rings.
Thanks in advance.
mrfish
by mrfish
In 99% of cases it will be fine.
But if the RD is already stretched when riding big-big as you've made a weightweenie miniumum length chain installation it is a good idea to test it very carefully in a workstand very gently before you ride, taking care that there's slack in the system before you make the final shift. Otherwise if you test it uphill in a sprint and the chain is too short you can wreck your frame, RD and likely the rear wheel.
Wonderman
by Wonderman
Hi, thank you for the reply,
What signs am I looking for that the chain maybe too tight?
Also do you have any idea what the correct chain length would be, as I'm going from 10 speed to 11 I don't think I can use the old one to measure can I?
McGilli
by McGilli
If you're in the big ring at the front - you don't want anything remotely like this happening....
Wonderman
by Wonderman
Hahaha excellent image!! I understand, hopefully will have this all sorted over the next couple of weeks and I'll post some pics of the finished thing (not looking like the above!!)
Wonderman
by Wonderman
Hi guys, update on this, the above pic shows the rd with the chain in big/big can I get away with that? I know it's not a combination I should use
MikeMoore
by MikeMoore
That looks fine.
However - is that with the 50 or the 53? If that is the 50, changing to the 53 may be pushing the limits of acceptability.
Weight 74.4kg, FTP 303W => 4.04 W/kg
Retired Bikes
Custom 650B Kingdom Double9
Kinesis Aithein / Kinesis Racelight 4S
Current bikes
Reilly Spectre / Cervelo R3
Pivot Les / Pivot Mach4SL
Ventana El Conquistador
Wonderman
by Wonderman
Hi Mike, no that's with 53/28, so I'm good to go?!
srshaw
by srshaw
My chain is a bit tight (da9000), and although big big does go, the chain rubs on a small pin at the bottom of the rear mech and makes a rubbing noise. If it runs quietly then I think you're fine.
Wonderman
by Wonderman
No it's pretty quiet, there's a little bit of a noise because the chain line is quite extreme but it's ok, I also removed the drive side space from the sisl2 so the chain line was better
