Look ZED2 crank q-factor?
I'm considering a Look 695 frameset and seems like you gotta use their cranks. I've gotten used to a very narrow Q-factor from BB30 + Cannondale SISL crankset which is 144mm and anything larger than that causes me knee pain. I've searched up and down Google for 2 days and couldn't arrive at any published figure for Look's ZED2 cranks. Does anyone happen to know what it is?
I used to have a Look 596 with the ZedTech crank. It's my FAR the narrowest crank I've ever used, incl PF30 SRAM Red, Campy SR, etc. etc. etc.
Thanks that really helps. I was on a SRAM Force 22 PF30 crank and that was too wide for me, causing agonising knee pain. I believe they are the same q-factor as SRAM RED cranks. If it's narrower than that, it should work! I was really hoping someone could take a ruler and measure the q-factor, it's really not in ANY literature from Look!
I will try to measure it tonight.
I measured 148mm, let me know if it makes sense.
yes I measured where the pedal are attached, for the indent not sure, it is minimal probably 1 mm each side at most. Here is how I measured it, I put a tape under my down tube, I draw a line in the center on the tape and then put the cranckarm in line with the downtube and then I used a sliding set square and put the sliding portion flushed with the carbon where the pedal are attached. Did the same for the other side and added them together. Probably not the most precised measured (maybe 1-2mm of play), but the best I could do.
Have you tried asking Look directly ?
Really appreciate your efforts, thanks so much. Probably means that the Look crank is 145mm q-factor.
Yeah, I sent an email last week to Look. They redirected my inquiry to a local dealer who wasn't able to answer my question. They didn't even know what q-factor was. Pretty sure not going to buy from them!
