Oval Chainring Users - does you chain ever fall off?
Hey all.
Started using some Doval chainrings yesterday - and if I gear from small front ring to large chain ring when the 'smallest' part of the ring is coming over (crank arm at 3 or 9 o'clock position) the chain will shift right past the chainring outside to the crank arm.
So - this only happens at 2 positions on the crank - all other positions it switches normally.
Does anyone have any tips on how to adjust the FD for these? Or is this something that is common?
My chainrings did not include any instructions - and I can't find any on the internet (Doval Rings) - I contacted the company and they said they don't have any in English - Regardless - would Q Rotor instructions work the same?
My Titanium Bike And Photo Blog
http://weightweenies.starbike.com/forum ... 5#p1246304
My $2k 12lb build Adventure!
viewtopic.php?f=10&t=133246&p=1151147#p1149264
Make sure you run the FD just above the tallest tooth - like the width of a penny (or 5c piece for australians) Be careful with your limit screws. I run Q rings on 3 bikes with no issues. Just be careful with your setup and you'll be fine.
My osymetric might drop chain if I try to shift from small to large ring while the chain is on the 11t-15t cogs... I just make sure it's on the upper half of the cassette first. Check that this is the real problem and if so perhaps a little mindfulness is all that's needed. I hardly uses the small ring so it's no biggie for me.
Sent from my SM-G900F using Tapatalk
I had been 'experimenting' with non-round rings for a number of years. In the final analysis, I was pretty convinced that there was a small benefit for certain, specific applications. I ran both of the 'Q'-Rings and the Osymetric rings. The adjustment of the front derailleur does take some doing, but it is no problem. While the use of chain-keepers is universally a good idea, it is almost a necessity for non-round rings.
Same issues (with SRAM) here, I run Yaw 22 on 2 bikes, and perfect adjustment is critical, but if I'm not careful it will still overshift onto the crank arm.
No issues with the 3rd bike with Ultegra though, but that one is on 34/46 while the others have 34/50.
I used to run Doval rings on my Ribble and found them a nightmare to set up. You have to get the FD adjustment spot on otherwise it overshifts or takes ages to jump onto the large ring. Even after I got it set up perfectly, after a couple of rides it would need doing again. Because of all this I ended up going back to my Rotor NoQ's.
This was just my personal experience of them, it may be different for other people. I found a couple of videos on YouTube that helped a bit, might be worth having a look.
My setup and experience no matter how many adjustments I go through
Q-Rings on TT bike with Di2 - from small to big ring shifting must be done without full power onto the pedals
Q-Rings on 10-speed and 11-speed Red - best to shift from small to big at certain pedal position and with a bit less power on the pedals
In both cases if not done as indicated the chain skips and does not stick on the big ring
I got used to it and really enjoy the ovals
I've been using Q-rings on all my bikes for quite a few years now (almost 10 years)… It does take quite a bit of work to set up the front derailleur to get it to shift smoothly and you want to avoid shifting under power. I rarely drop a chain, but when it does, it's usually that I haven't set up the derailleur to 100%, neglected to clean the chain and shifted under a bit more power than I really should've...
Using Q-rings since 2012 and I've had no issues with the chain falling off in any situation. On 10 speed SRAM Red. I did have a real hard time setting them up to shift properly though. As long as I'm at a "normal" pedaling cadence...the shifts are immediate...but if I'm slow pedaling down my street...then the chain will drag a bit before moving up to the big ring.
