ee cycleworks brake issues
Having issues with the EE Cycleworks direct mounted brakes on my De Rosa King XS. Presently running Lightweight Gipfelsturm wheels. However, the brake holders sit too low on the wheel. So half of the pad is on the brake surface and the other half is on the wheel. Apparently, they are designed to the same specification as Shimano direct mounted brakes. Anyone have any ideas? Spoke to Craig Edwards of EE, he can't work it out either.
- Stolichnaya
Pictures of this predicament would help.
Post some shots up taken from the side and straight on.
the newer EE brakes don't have the extra adjustment of moving the entire brake assembly up or down (eccentric bolt). the older ones have the adjustment bolt...the newer ones do not...although i never came across any issues with any brake surfaces yet with the newer EE brakes.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
kode54 wrote:the newer EE brakes don't have the extra adjustment of moving the entire brake assembly up or down (eccentric bolt). the older ones have the adjustment bolt...the newer ones do not...although i never came across any issues with any brake surfaces yet with the newer EE brakes.
thanks for the info - shame there wasn't an industry standard !
- wheelsONfire
How weird! I have used my 2015 standard mount on THM CT fork, Ax Lightness Helios, and Paduano racing fork, no problems.
What is so different with direct mount version?
Bikes:
Open *UP* (2016.04.14)
