ee cycleworks brake issues
Lafolie
by Lafolie
elfuinha wrote:If you are describing the issue right these pads could work..
yes you are right.....just got to find them now ! :-)
micky
by micky
Solved the problem?
Marin
by Marin
Ugh why not take a carpet knife to a set of standard pads? Or is this solution not expensive enough for LW/EE/THM? :D :D
kode54
by kode54
Lafolie wrote:Now trying to track down these specially milled Lightweight brake pads as I think they could just be the answer !!!
or swap with someone that has them half worn. i'm sure there's quite a few here that have shaved down pads by now.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
Marin
by Marin
They're shaved in a different way though...
ferrarista
by ferrarista
You could always use some offset brake pad holders like the ones made for gigantex carbon rims. Those are made for lowered brake track , but you can install them inverted so that the pads are offset higher. this way you won't have to buy special pads from lightweight and can use your regular pads.
Bike hub store is selling some: http://www.bikehubstore.com/product-p/gtxholder.htm
you could have them anodized black or just sand them a bit and use etching black primer. Etching primer sticks very well and will match the finish of the brakes.
BeeSeeBee
by BeeSeeBee
You can probably just take a Dremel to a standard pad, that's what I have to do for my Hed Jets, it takes all of 5 minutes to grind them down.
