switching rings mid-compact to compact Campy 2015 cranks-
Hello,
I'm headed into the mountains for a couple weeks and was thinking about taking advantage of the fact that the new 2015 Campy cranks can evidently switch rings - compact, mid-compact, traditional. I'm currently all dialed in on a mid-compact and was wondering if switching out to compact rings would be as simple as switching out the rings, easy as that, or do I need to adjust the front deraileur and possibly take out some chain links? Advice is very much appreciated!
Thanks in advance
Thanks in advance
- bikerjulio
Campy rings are proprietary, very hard to find, and very expensive if you do. Campy does not encourage user change of rings preferring it be done at a service centre.
Probably cheaper to buy a new crankset. (hint, 10-speed work just fine on 11-speed systems).
Adjust FD? Yes. Take out link? Not unless the chain is way too long already.
Your improvement in low gear is only going to be from a 36T to a 34T.
You should be on a 29T biggest sprocket. Are you?
There's sometimes a buggy.
One.
One.
I changed out my compact 50/34 to 52/34. Yes, I know Campy says 52/34 is a no-no but front shifting performance is identical to 50/34. New ring bolts are included and the swap is a no-brainer. Raising fr der slightly was only necessary adjustment.
TA
Crazy talk : http://www.starbike.com/en/campagnolo-c ... eed-4-arm/
Just switch out the 36, works perfect
