Campagnolo Brake & Gear Housing Ferrules Size ?
- bikerjulio
Campy does not use ferrules on brake housing.
On derailleur housing, it is no longer used in the shifter, but is on other locations on the frame. The ferrule is 5.7 mm OD and 4.6 mm ID. It is used on both the older and current (ultra low friction) derailleur housing.
There's sometimes a buggy.
One.
One.
So the gear housing is 4.1mm (outer diameter) and the brake housing is 5.9mm based on Campagnolo's documentation.
I can easily find 6mm ferrules in black but I can't find anything for the gear housing in black. The 4mm ferrules won't fit. Any suggestions ?
- bikerjulio
These are 4 mm in the title, but the detail is 4.3 mm, so the 4 mm you are typically seeing may be nominal
don't think eBay links are allowed. Not sure about eBay stores.
http://stores.ebay.com/CyclistPoint/_i.html?_nkw=ferrules&submit=Search&_sid=995221452
One.
One.
