It is currently Sat Oct 21, 2017 4:57 pm
Post new topic  Reply to topic  [ 68 posts ]  Go to page 1 2 3 4 5 Next
 Post subject: THM-Clavicula SE
PostPosted: Thu Jul 09, 2015 1:50 pm
Today is got THM-Clavicula SE Crankset from STARBIKE !! (My friend's)
Very long long time wait (i think to last year december reservation)
Super Light weight .
Spec : 170mm / glossy / bcd110
Actual Weight : 283.99g
Driveside : 169.42g
Non-Driveside : 107.17g
Preload Cap : 4.48g
File comment: Actual Weight : 283.99g
File comment: Non-Driveside : 107.17g
File comment: Driveside : 169.42g
File comment: Preload Cap : 4.48g
File comment: Spacer
  • THM Carbones Clavicula SE cranks Compact 110mm 172.5 mm shiny
  • 1149 EUR
  • IN STOCK
  • Price includes 19% V.A.T. which will be deducted when goods are leaving the EU. Shipping costs may be added.
 Post subject: Re: THM-Clavicula SE
PostPosted: Thu Jul 09, 2015 2:15 pm
Does it matter that Shimano and Campagnolo have switched to 4 contact points (the star that connects to the chain ring), but the THM Clavicula SE still has 5? Will that lead to issues down the road with chain rings etc? Also, there ought to be a reason for switching from 5 to 4. Would seem to make sense to implement that change here as well, wouldn't it?
Otherwise it looks and seems utterly amazing!
Specialized Venge Pro Disc 8,3 kg
PostPosted: Thu Jul 09, 2015 2:22 pm
Why would it?
There are many versions of 5 contact points. Just look at the new FSA K-force light using their own design.
It seems as 4 contact points, but there is a fifth at the crank arm.
If THM had used 4 contact points, what chainrings would you suggest people would use with it?
Bikes:
Ax Lightness Vial EVO D
Paduano Racing Fidia
Open *UP*
PostPosted: Thu Jul 09, 2015 2:27 pm
Not finding fault. Was a genuine question. I love the look of the THM crank and may get it on the next bike if I can justify the expense with my conscience. :wink:
I was curious if the 4 point option had any advantage to the 5 point one; and why both Shimano and Campagnolo made the switch.
PostPosted: Thu Jul 09, 2015 8:35 pm
MRM, i don't remember. But one thing might be, you need not decide of either of 110 or 130bcd . You can hook up what ever rings you prefer instead of being forced using either compact or standard bcd. This is same with FSA K-force.
Stripped of rings K-force light BB 386 EVO is 410 grams (172.5mm version).
If i am correct, the typical 5 contact point cranks are still requiring either compact or standard.
I weighted for instance, K-force in both 52/36 and 53/39. The latter is 25 grams more heavy and the first was 560 grams.
So if you buy Clavicula SE, you can get a much lighter set. I know THM recommends Praxis due to many light weight chainrings lesser shifting quality.
Bikes:
Open *UP*
PostPosted: Thu Jul 09, 2015 10:04 pm
Thanks wheelsONfire. :)
PostPosted: Wed Jul 15, 2015 2:36 pm
@minimini: what frame does this crankset go on? can you post pics as soon as you have attached chainrings and bolts, please? and maybe one more including the bottom bracket... thanks!
My contribution to more beautiful roads: - old - / - new -
PostPosted: Wed Jul 15, 2015 5:07 pm
Thanks for those weights. That is a beautiful piece of workmanship.
For comparison, my Red 22 BB30 cranks 175mm were 370 grams without rings (same config as yours is shown).
PostPosted: Wed Jul 15, 2015 6:15 pm
Only 90 grams heavier and 30% of the price, one of the best deals in terms of crank sets.
PostPosted: Wed Jul 15, 2015 6:41 pm
Want the most extreme, the price is also the most extreme :mrgreen:
Bikes:
Open *UP*
PostPosted: Wed Jul 15, 2015 7:13 pm
For Weight Weenies, 90 grams is a lot!
PostPosted: Wed Jul 15, 2015 7:52 pm
700 Euros are also a lot, for 90 grams.
Anyway, if money was no object then I wouldn't think twice either! :-))
PostPosted: Tue Sep 01, 2015 2:43 am
Does anyone know where I can get my hands on a set of this? 170mm?
Sent from my Nokia 3310
The Harem
Speedvagen | Argonaut 2.0 | Pinarello F10 | Mosaic RT-1 | Festka Scalatore | Pegoretti Responsorium Ciavete | Wilier Cento10Air Ramato | Trek Madone 9
Incoming
Rob English | Field
Ex's:
Factor | Field | Baum | Stinner
PostPosted: Tue Sep 01, 2015 3:59 am
Starbike, the shop that hosts this forum, as them.
  • 1149 EUR
  • IN STOCK
PostPosted: Tue Sep 01, 2015 5:07 am
Just dropped them an email! Let's keep our fingers crossed for a favourable reply...
The Harem
Incoming
Rob English | Field
Ex's:
There are no new unread posts for this topic. Attachment(s) THM Clavicula SE installation
adamdoc12
Tue May 23, 2017 2:00 am
audiophilitis View the latest post
There are no new unread posts for this topic. Ceramicspeed BB with Clavicula
leej88
26
1851
Fri Apr 14, 2017 8:57 am
benp View the latest post
There are no new unread posts for this topic. Clavicula BB for Colnago 60
jimaizumi
Tue Oct 03, 2017 8:51 pm
ironman1 View the latest post
There are no new unread posts for this topic. THM Clavicula SE on 2017 Supersix Evo
syvid
10
1133
Tue Aug 01, 2017 3:48 pm
jinnie799 View the latest post
There are no new unread posts for this topic. Attachment(s) Crank arm fell off. [thm clavicula]
KCookie
41
3719
Thu Dec 01, 2016 5:08 pm
qorwlch View the latest post
Users browsing this forum: Bing [Bot], Delorre, Everyone, nafaiutb, probertsqbe, Samklee15 and 28 guests
