Cannondale Super 6 Evo Nano Black (2015) - Stock Weight?
- Contact:
Hi,
Just wondering if anyone knows the out-of-box weight of a stock Cannondale Super 6 Evo Nano Black (2015)? (preferably a 54cm!)
http://www.westbrookcycles.co.uk/cannon ... 15-p258010
- Contact:
Answering my own question...
...this video claims "about 11lbs" (5kgs) for a 56cm version (at the 1.07 minute mark).
Cheapest UK price atm is around £5k...
Not to burst your bubble but it's likely closer to 12.5lbs.
Here's a list of 2014 build weights https://scontent-lax1-1.xx.fbcdn.net/hp ... e=5616DB89
And 2016 weights http://www.bikerumor.com/2015/07/09/201 ... l-weights/
- Contact:
That does seem more realistic
So somewhere between 5.5 and 5.8kg, based on 2014 / 2016.
What do you make of the build for £5k?
Dura-ace mechanical, Enve 3.4s, Enve finishing kit and Nano frame (which seems to have been dropped for 2016's version...).
- Contact:
Went to have a look at one of these at Bespoke Cycling, Canary Wharf - they have a 56cm officially listed @ 5.2Kg
- Contact:
airwise wrote:Next years model is 5.8kg without pedals and runs tubulars so I would be amazed if the 2015 was much below 6kg in reality.
I'm sceptical too.
Although tubs rules out the 2016 version for me, plus they've dropped the Nano frame completely.
The 2016 Evo range will use 52/36 for the SiSL2 cranks though - wonder if they'll be available to buy separately?
My 2015 SS black inc in 52cm is 14lb stock with Dura Ace pedals. I don know where they get 11lb from!
Same here mashiehood! My 2015 SS is 14.14LBS on a 56CM frame with Vector pedals. Not close to 11LBS. Do we know why??? Anyone from c'dale can explain?
