201x Specialized Allez Sprint DSW and Gen2
pyrahna
by pyrahna
IrrelevantD wrote:
morganb wrote:I had one of the gold ano 2x models and the headset was notchy after a month. My friend got the Specialized Edition 2x and they warrantied his headset after 3 or 4 weeks because it was nearly seized. Maybe they have fixed it in the more recent ones or made a change from the 1x to 2x but there were issues for sure.
I'm curious, do you guys live in a particularly wet or humid area? I've been through a couple of headsets on my other bikes, but rarely shorter than 18 or so months (8~10k miles). My rides are usually pre-dawn in the Dallas area when it's really humid and muggy. I also do not shy away from riding in the wet unless there's ice on the ground or lightning in the skys, so I can be really hard on equipment. I'd be very surprised to see a headset go out after only a few months. I really hate saying this, but my initial gut reaction was that something was missing like maybe the plastic ring that mvcap referenced and there's moisture getting in there somehow.
For the record I live in Savannah, Ga, do not fear the rain, ride it on the trainer indoors a bunch, and sweat battery acid. Haven't had a problem in 18 months of owning the 1st one, or the 1st month of owning a 2nd additional one.
morganb
by morganb
Pittsburgh, so yes it rains half of the days here. But still both of us replaced the bearings with more FSA/Spec ones and the second set were fine and lasted. I traded the gold Allez to my friend this spring and he never had any issues with the second one, just wanted to see if there were other options out there since I had trouble with the stock ones.
morganb
by morganb
On a completely unrelated note, does anyone know if you can run linked brake housing through the top tube? I figure that would help mitigate some of the impact of having to run full length housing for the rear brake.
IrrelevantD
by IrrelevantD
morganb wrote:On a completely unrelated note, does anyone know if you can run linked brake housing through the top tube? I figure that would help mitigate some of the impact of having to run full length housing for the rear brake.
I saw someone post somewhere, and I don't know where I saw it, that trying to run linked housing was problematic at best, IE: not possible. That being said, I'm using standard Shimano housing with 6800 Ultegra brakes and I'm having no issues with my brakes. Unless you are talking about weight, not sure what "impact" you are referring to.
kfink117
by kfink117
I tried too. 'Problematic at best' is accurate.
morganb
by morganb
I find full length housing tends to amplifying the feel difference between the front and rear brake more because there is 5x more housing to compress. Its not unusable by any means but I prefer the feel of bikes that run minimal housing whether external or with cable stops internal.
IrrelevantD
by IrrelevantD
morganb wrote:I find full length housing tends to amplifying the feel difference between the front and rear brake more because there is 5x more housing to compress. Its not unusable by any means but I prefer the feel of bikes that run minimal housing whether external or with cable stops internal.
Fair enough. Personally, I find the rear brake to be more responsive and a better feel than on my similarly equipped '05 S-Works Tarmac (6800 mechanical) which is open under the top tube, but that could be due to older cable/housing/pads on the Tarmac.
[not even going to discuss the difference between this and the Giant Propel it replaced. Two words... v-brakes suck]
morganb
by morganb
Routed all the Di2 wires for my bike this evening, but forgot to buy a chain at the shop so I'm going to wait until tomorrow to finish it. I ended up using a dremel on the brake stop to run the wire along the rear brake housing and then through the headtube.
IrrelevantD
by IrrelevantD
morganb wrote:I ended up using a dremel on the brake stop to run the wire along the rear brake housing and then through the headtube.
Not sure I follow what you did on this one. Any chance you can post some pictures?
morganb
by morganb
Will do tomorrow, and post some better pics of the bike. Once I put some heat shrink around it the only exposed cables should be at the derailleurs. Got the first test ride in today with a surprise climb of Sycamore Ave (12%) which is currently torn up and exposed cobbles and dirt. Need to wrap the bars once I am set on the sprint shifter positions and it should be complete.
moock
by moock
Here is a Pic of my 17' Allez Sprint. Hope you like it.
Delorre
by Delorre
moock wrote:Image
What crankset is that? Nice and agressive bike btw :thumbup:
mvcap
by mvcap
This was worth the wait ImageImage
Sent from my Nexus 6P using Tapatalk
moock
by moock
standart Praxis Alba( i think !?) which came with the bike.
morganb
by morganb
Its hard to see without me removing the cable stop, but I basically dremeled a slot on the back side of the stop down to the point that it flattens out near the bolt, then I drilled a hole just big enough for a Di2 cable (not the end) and slid it in place. I then pushed the brake housing through, so I can't remove the Di2 cable without removing the brake housing, but it looks much cleaner.
