201x Specialized Allez Sprint DSW and Gen2
- Contact:
Long known about issue... it probably discussed back on page 3 or 4 or something. It doesn't effect all bikes, just the smaller sizes. I think 49, 52 and maybe 54.
Incidentally, this same issue effects the new Tarmac but ee has developed some sort of bracket to fix it. Unfortunately, the Tarmac is direct mount, not standard mount like the Allez, so the Tarmac one wouldn't work.
This is a 54cm frame. Really pissed that eebrake can't fit...CrankAddictsRich wrote: ↑Sat Jan 06, 2018 6:54 pmLong known about issue... it probably discussed back on page 3 or 4 or something. It doesn't effect all bikes, just the smaller sizes. I think 49, 52 and maybe 54.
Bummed too, I have a set on my SL5 Tarmac and was going to transfer them over to my Sprint when I upgrade to the SL6.itguy wrote: ↑Sat Jan 06, 2018 7:35 pmThis is a 54cm frame. Really pissed that eebrake can't fit...CrankAddictsRich wrote: ↑Sat Jan 06, 2018 6:54 pmLong known about issue... it probably discussed back on page 3 or 4 or something. It doesn't effect all bikes, just the smaller sizes. I think 49, 52 and maybe 54.
Has anyone tried the 'short arm' version they made for the new tarmac? I doubt it would work, as the tarmac also uses a spacer to angle it away...but it might be worth a try. Then again they may only make the 'short arm' in direct mount, which obviously won't work on the Allez Sprint.CrankAddictsRich wrote: ↑Sat Jan 06, 2018 6:54 pmLong known about issue... it probably discussed back on page 3 or 4 or something. It doesn't effect all bikes, just the smaller sizes. I think 49, 52 and maybe 54.
- Contact:
the new Tarmac is direct mount, the Allez sprint is not, so the ee for the Tarmac will not fit.pyrahna wrote: ↑Tue Jan 09, 2018 3:40 pm
The arm part is not specific to direct mount vs. traditional. I didn't know if they sold the single bolt mount w/ the short arm.CrankAddictsRich wrote: ↑Tue Jan 09, 2018 4:23 pmthe new Tarmac is direct mount, the Allez sprint is not, so the ee for the Tarmac will not fit.pyrahna wrote: ↑Tue Jan 09, 2018 3:40 pm
- Contact:
I have traditional mount ee's and while I have not worked on direct mount he's myself, I did photograph a bike that had them and while the two models do look similar, if I remember correctly, they aren't exactly the same. I'd be surprised if those parts are interchangeable, but maybe I'm wrong. In any case, I don't think the arm alone would fix the issue. The Tarmac still requires the angled mount, so you'd need to buy a short arm, direct mount brake to take apart the arm and then machine a mount.pyrahna wrote: ↑Tue Jan 09, 2018 4:25 pmThe arm part is not specific to direct mount vs. traditional. I didn't know if they sold the single bolt mount w/ the short arm.CrankAddictsRich wrote: ↑Tue Jan 09, 2018 4:23 pm
Hi, I'm using size 54cm does these 2 things work on the rear eebrake?AttacknowAttackoften wrote: ↑Thu Jan 05, 2017 5:07 pm"Eli,
Okay! we have a couple small parts that will replace the current adjust barrel with the wings that you have currently. These 2 small parts, include a adjuster barrel and plastic pad, that will not interfere with the aero seat tube.
The part numbers are as follows.
1 quantity AEE0112 (Legacy adjuster pad)
1 quantity AEE0113 (Legacy adjuster nut)"
I will report back here once the parts arrive.
- Contact:
Go to page 25-26... there are pics, still rubs.itguy wrote: ↑Wed Jan 10, 2018 4:15 pmHi, I'm using size 54cm does these 2 things work on the rear eebrake?AttacknowAttackoften wrote: ↑Thu Jan 05, 2017 5:07 pm"Eli,
- Moderator
Sent from my SM-N950F using Tapatalk
Using Tapatalk
How many spacers are you running? I would think a 52 would make more sense as you would need an 80mm stem on the 54 to replicate your reach, additionally there isn't much slope on the top tube of the 54 so unless you have very long legs for your height you won't have much post showing.
