Thinking about running 1x10 for youth races
I'm thinking about running 1x10 for youth races.
36x11 would give me the gear rollout I need. I have Sram Red 2013 with a 110bcd crankset.
I have a few questions about running this. How would I set up the single chainring on a Sram red crankset? I don't want to spend much money.
What would the chain line be like with this? Would I need a chain guide?
Thanks
Thanks
This doesn't answer specifics of your question, but I recently converted my commuter/CX bike to SRAM 1x10. I replaced my 36/46 rings with a 46t X-SYNC ring. It is an outer ring, but teeth are offset inboard to help center chainline. If you are really just gonna run a 36t you can choose whatever narrow/wide you want and mount on inside for best chainline. OTOH with a 36t you might be spending more time on the outside of the cassette? Some frames might accommodate a 42t as inner ring too. (I am assuming here that the 110 bcd SRAM Red spider is not a proprietary design.)
I also installed a mtb clutch derailleur, since I wanted to use an 11-36 cassette (11-36 + 46t is same range as 11-28 + 36t/46t rings), but I rode around on my 11-28 + Rival derailleur for awhile. I suspect for road riding the clutch derailleur is not really necessary to keep chain on? Narrow/wide ring did great for the bit of road riding I did. No chain retension device was needed. For riding in single track, the clutch derailleur is really nice (quiet, no dropped chains), though.
On the whole I am very happy with the setup, though for strictly road riding I think the tighter gear spacing is worth the "hassle" of the front shifting apparatus.
Yes, if you wanted to use the same bolts, you would need spacers. The SRAM X-SYNC ring comes with the spacers, which is nice.
You could do 1x10 without a narrow/wide, but suspect you would have to deal with dropped chains unless you use a chain guide.
I recently set this up for a junior.
DA Di2 I increased the spring tension in the RD & fitted a praxis 40t narrow wide & put a K-Edge cross catcher on for extra protection.
Set up with a junior cassette as well.
He loved it.
He loved it.
Pottsy, more pics please
this bike looks sweet <3
Terrific!
Junior always sounds like some kid riding around on a S-Works Nibali frame with lightweight wheels.
ok. It shold come around 45 X 14 then...
I know running standard cassettes is lighter than a junior one (especially since this is WW , although a few people here have made very light junior cassettes), but the difference in gearing is smaller running a bigger chainring in front like a 45T and a junior 14-25 cassette.
I'd choose 45 X 14 over 36 X 11 personnally.
Louis
Louis
