light bb86 crankset verdict ?
felipedana
by felipedana
Hi all,
So, I'm looking for a light crankset compatible with bb86.5 (for a look 675), and after spending a couple of hours searching I still couldn't find an answer to the BB86 problem... lightning or clavicula seems to be answer with their compatible bb86 cups, but MANY report that it's too small to be reliable ..
Any Clavicula or Lightning owners using bb86? is there any other lightweight option?
hopefully I'm missing something... opinions are welcome..
felipedana
by felipedana
note: I'm probably going dura ace di2 for this but I wanted something else for the crank, unless it's really my best option
Delorre
by Delorre
I'm in the same boat, and I'm going to sand down my '14 Campy ultra torque TI compact crankset (575gr with TA rings, incl bearings) and give it a new layer of clear coat. Check my opcoming Scott addict team issue build topic ;-) Will be build with Di2 as well.
prebsy
by prebsy
I've been really impressed with the sanded Red Exograms + aftermarket rings I've seen people do.
Here is one from @juggler
Delorre
by Delorre
prebsy wrote:I've been really impressed with the sanded Red Exograms + aftermarket rings I've seen people do.
Totally agree, but that's a BB30 one for sure. The regular GPX for BB86 is a lot heavier than that :cry: So, no option fur us... My UT weights only slightly more with bearings incl and the cups are only 30gr...
felipedana
by felipedana
anyone is using the Lightning crack w/ bb86 ?? I would really like to hear some feedback
hornedfrog
by hornedfrog
No, that is the "GXP" version. Notice the spindle is attached to the drive side. BB30 has the spindle attached to the non drive side crank arm.
Tomstr
by Tomstr
Handsome cranks!
Interesting topic too, I'm also looking for a set of light and affordable cranks. A set of Sram GXP looks interesting!
Ride it like you stole it
KarlC
by KarlC
prebsy wrote:I've been really impressed with the sanded Sram GXP Red Exograms + aftermarket rings I've seen people do.
Looks great whats a set up like this cost ?
I have a BB86 also on my BMC TMR01, I wonder how much weight I would lose compared to a Ultegra 6700 ?
Can I reuse my bottom bracket with the Sram GXP crank ?
The matt sanded finish would match my frame well also.
C64 My Sixty 4 SR EPS 12
Kayrehn
by Kayrehn
My sanded then clear coated sram red gxp cranks 175cm weighed in at 480gms without rings.
Sent from my SM-G900F using Tapatalk
