Sticky 9000 rear brake cable
Bike is less than a year old, low miles also. I had new dura ace 9000 installed throughout including cables/housing. The rear brake has become very 'sticky' and makes a squeaking noise when I pull on it, and also it requires more force than usual. You can feel the cable 'stepping' as you squeeze harder. Seems like the friction and noise is coming from the front end of the bike but hard to tell.
What's the solution? How can this be happening after < 12 months. My other bikes have gone 3 years or more before needing to look at cables etc. I would have thought cables should go for at least a couple of years before needing replacing. Is it the housing or the cable itself? Can I relube it? With what grease or lube?
Quite annoyed as I haven't even had my first tuneup since buying the bike as only around 1000kms on it.
Many thanks
Many thanks
Haven't seen too many issues with the rear brake cable but the rear dérailleur cable is notorious for fraying at the sharp bend as it comes out of the 9000 shifter. Seems every 3-4 months or so for a regular rider.
I would start by replacing the cable and see if that sorts it out. That coating comes off and while Shimano may say it doesn't matter, that is only true in an ideal world with no dust and grit and water ingress. Mix that soft fluffy frayed coating that's come off with those ingredients and you have a fine yucky mess. Replacing just the cable assumes you've got no obvious routing issues either, which should be addressed first if possible.
The 9000 polymer cables require specific ferrules that have lead in tubes. If you don't use them, the cable rubs the sharp edges of regular ferrules and this causes the polymer thread to bunch up and stick. My guess is that regular ferrules are on your bike instead of the shimano ones with the lead in tubes.
The cables and housing have done 1000km. Should they last longer than that? I have done 10000 on 6700, no fraying and starting to get a bit stiffer so will replace soon. I didn't think 10,000 would be out of the question.
Ridley noah.
Just by looking at my cables is there anyway to tell whether the housings are dura 9000?
Ridley noah.
Ok. Cables appear slightly brown in Colour - good news (may well be 9000) +1
Can see lead in tubes inside the caliper / I gather these are exclusive to dura 9000 +1
Barrel adjustors have been installed (could mean cheap aftermarket cable sleeves at the front). Sleeves are marked 'LE' -1
Yes - bike has internal routing though top tube to rear of bike for rear brake;
Rear derailleur cable is marked Ot-sp41, which I gather is 9000.
