Scott Addict SL 2015 - di2 ready?
Nejmann
by Nejmann
Does anyone know if the Scott Addict SL is di2 ready? I can only find it with sram red, i need it as a frameset.
Thanks!
ms6073
by ms6073
I can't answer the question directly, but we own the 2015 Scott Solace and Contessa Solace framesets which we run with Di2 but they were supplied with hardware for both mechanical and Di2 options. I will also add that the 2014 Team Issue was Di2 so one would think that Scott would persist that feature for 2015.
- Michael
kim
by kim
2014 is not ready
2015 ready
BrunoDMS
by BrunoDMS
kim wrote:2014 is not ready
2015 ready
Scott addict sl 2015 and Dura Ace 9070 Di2....
Are you sure?
___
Sorry I don't speak English
Delorre
by Delorre
2015 ready
You 'could' use di2 on the new SL 2015 ones, as on most frames with internal cable routing, but the ME frames have 2 cable entry's, and the cable entry is profiled, whether on the di2 frames (I own one) it's only a hole on which you put a grommet. Not sure you could use a grommet on the ME frames. On The ME frames, not sure also there is a hole for the front mech wire, or you have to use the hole for the mechanical front derailleur.
BrunoDMS
by BrunoDMS
I asked directly to Scott Italy.
They confirmed me that "Addict SL" can't mount DA9000-2 for a precise SCOTT choice.
___
