Hi there,
This is my first time building a bike and I've run into an issue with the brakes. The BMC TMR has integrated brakes and one of the arms isn't pulling in as far as the other, this causes the bakes to rub on one side and the other side's arm to stick way out. I'm at a bit of a loss on how to adjust this sort of thing, anybody got any ideas? Below are some pictures to make it more clear. Thank
Pic from the bottom showing the brakes
Right side pic showing brake arm aligned with the chainstay
Left side pic showing brake arm sticking out further than the chainstay
BMC TMR Integrated Brake Arms Not Aligned
Adjust them as you would any old V-brake. I'm not familiar with this model in particular but I assume that blue colored grub screw in the bottom left of the 1st pic, that adjusts spring tension for that brake arm. Tighten/loosen either side until the brakes are even with the rim, pull the brake lever and see if both levers close simultaneously, and if they don't, adjust those screws some more until they do.
