How light is(n't) your saddle bag?
If I had a nickel for every ziplock bag of stuff, keys, phones, etc. I've seen on the side of the road I'd buy a new bike.
I don't know, I use a saddle bag.
You're probably right!
125g, plus a Lezyne pump in the jersey pocket
Most times I put the bag in the Jersey too though.
* 1 Conti supersonic tube in a plastic bag with valve extension & cap mounted
* 2 Conti tire levers, 1 modified to have a spoke hook & 1 just lightened a bit
* sandpaper
* 6 patches - 4 small 2 large
* glue
* 3 banknotes for Haribo & tire patching
* another valve extender
* 2 cable ties, just in case
* Ritchey CPR-9 tool, with the 6mm allen cut off, under 20g now
* 2.5mm allen key for Sram derailleur adjustment
* a pair of surgical rubber gloves, if I'm out on the bike with the white bar tape and have a drivetrain problem
* sandpaper
* glue
I'm using a Scicon Elan 210 Caronium saddle bag, with:
1x Continental Race 28 tire
1x Set Tacx Mini Tyre levers T4885 (Very lightweight and well designed tire levers: http://www.remo-knops.com/5101/tacx-min ... ers-t4885/
1x Topeak Micro AirBooster CO2
1x CO2 cartridge 12 gr
https://www.cycling-review.net
0.0g, however, I do ride with a Garmin Virb on the back of my bike to record the ride.
Madone 9 - https://bit.ly/2Nqedbn
Emonda SLR - https://bit.ly/2UK5FP8
Crockett - https://bit.ly/2Xem4sk
Ozrider wrote:I keep it simple
Lezyne carbon pump - mounted on seat bottle cage. Pump weighs less than a canister and inflator and can be used multiple times
Arundel Uno saddle bag
1 x Conti race light tube
1 x Pack Lezyne or Park patches
2 x Michelin tyre levers
Total about 280g
This is pretty much what I do except I carry the mini pump in my jersey pocket. I hate the look of any pump mounted on a bike.
For most rides when I'm not venturing too far:
1 tube
1 pedro lever
1 Lezyne road drive alu pump (in pocket)
I keep everything in my jersey pocket.
1 tube
1 pedro lever
413g
Vittoria Evo Crono 22mm w/ 88mm valve - 181 g
Shimano Pro Medi Quickrelease - 112 g
2 x 12 g CO2 - 83 g
1 x Pedros lever - 21 g
Genuine Innovations Airchuck - 16 g
2 x 12 g CO2 - 83 g
480g
tube
tire lever x2
co2 x2 and adapter
patch kit
Phone doesn't fit in the bag so it goes in a pocket.
tube
tire lever x2
co2 x2 and adapter
patch kit
