KMC 11 speed chain on Campy drive train?
DeLuz
by DeLuz
I am building a new bike with Campy 11 speed, don't want to spend money on new chain tools. I have had good luck with KMC 10 speed chains on Shimano. Does their X11SL 11 speed work as good as a Campy chain? Shifting and noise are most important. I don't ride a ton of miles so life not so important.
stormur
by stormur
KMC works more than fine. However you don't need C chain tool… I use PT 4 series tool and KMC missing link - it works very fine ( never had any issues with it, not on Centaur, not on Chorus )
Mark Twain
havana
by havana
You only need an 11-speed chain tool to close a chain (w/ linking pin). To shorten an 11-speed chain you can a simple 10-speed chain tool.
P.S. In my experience, no KMC chain is as durable and silent as Campag's own chains.
P.S. 2 Lezyne makes a decent, cheap 11 speed chain tool.
Editor-in-chief CycloWorld.cc - the largest database of gran fondo's and sportives in the world.
liam7020
by liam7020
In my experience KMC 11 speed chains work every bit as good as Campag or Shimano.
Tarmac SL6 & Campag Record EPS https://weightweenies.starbike.com/foru ... 0&t=153968
choiboi
by choiboi
Perfect with my sr11
David
[b]'10 CANNONDALE CAAD10
Timujin
by Timujin
no problems on my SR11..
Harmitc
by Harmitc
Every bit as good as R11 chains. Never noticed any difference in shifting.
sub7kg
by sub7kg
I use them on my SR, work fine easier to fit, cheaper to replace. Stick one on for now try a campaign one next time if you really want to.
Dman
by Dman
I use the KMC X11SL Black DLC with new SR. My opinion is that it's just as quiet and shifts equally as well. I think your cables, housing and tuning will have a greater effect.
The more I ride, the less I spend
Dodger747
by Dodger747
As with the above, works just as well on my SR11.
VO2 Max - 79 ml/kg/min
W/kg - 4.9
glam2deaf
by glam2deaf
Another check in to say yup, works perfect.
mike
Resident Pro
by mike
Kmc is the only perfectly good substitute for record 11. Campy chains though last longer, more durable imo.
nlouthan
by nlouthan
What are people's experiences with reusing the missing link? It looks like KMC recommends not, but I'm sure I've read posts here stating it's been successfully.
ross
by ross
Have reused the same 11spd missing link 5 or 6 times on the same chain, by removing it for cleaning and refitting. As long as you are careful not to bend the side plates on removal it's all good
