boysa wrote:I also had been thinking about this, since as of late my Zeros were rocking quite a bit. I had changed the cleats not long ago, so I realized it was the pedal body that was worn. I was tempted to give the Pave a try, but since I need to use them with the adaptor plate... wouldn't they just wear out the plates much faster? IOW, I'd be replacing cleats quite often, and they aren't the cheapest. Unless, of course, someone can point me in the direction of a good source for cheap plates.
I don't see how the plates help in the wear of the cleat or pedal. The plates do not really bear any loads too much. (perhaps when really hammering or sprinting..) Speedplay does have the (again going more heavier than the normal Zeros) metal adapter plates, which I imagine wouldn't give as much play as with the plastic ones. I was thinking modifying the cleats or pedal with a method someone else mentioned; teflon shims. In my opinion the metal plates can be made out of plastic, which I did in the beginning as well.. Milk jugs, plastic packaging from christmas presents etc..
Also buying the Speedplay Aluminium Fore-Aft Extender plates is one choice..
edit: the plates, adaptor plates and the metal plates...
edit2: just found on ebay, it seems to only contain the adaptor plates and screws required: http://www.ebay.co.uk/itm/Speedplay-Cle ... SwnipWZFzV
Part number 13000 it is then?
