Canyon Aeroad CF SLX S size Power meeter crank clearance
mudrii
by mudrii
Hi
Need Help from the owners of the Canyon Aeroad CF SLX S size with crank Shimano 170 mm.
I order the frame set from Canyon https://www.canyon.com/en/roadbikes/bike.html?b=3692# and Power meeter from 4iiii http://4iiii.com/product/precision/ for 52/36 chain ring .
I asked Canyon to provide information on clearance for power meeter if I can feet in the power meeter but Canyon reply they can't provide this information that is really strange...
Can anybody who have the Aeroad CF SLX bike or frame help with measurements of the clearance between the crank and frame ?
Much appreciate.
el condor
by el condor
mudrii wrote:Hi
Much appreciate.
Hi, I will check once I get home. I can recall that the gap between the tip of the crank arm ( 172.5mm) when pointing rear-ward and the chain stays measure about 13mm's.
Hope that helps so far. Will measure the gap from the middle of the crank arm (where the power measuring device will be)-to the chain stay.
el condor
by el condor
So I measured, it's 13mm.
mudrii
by mudrii
Much appreciat for help
mudrii
by mudrii
Hi el condor
Please would you able to exactly point the distance from below scheema
http://road.cc/sites/default/files/Cran ... iagram.png
Thank you
dalex
by dalex
el condor wrote:So I measured, it's 13mm.
I have another Aeroad measurement question – I would like to know the distance available for the rear dual mount brakes, in particular the distance from the rear brake mounts to the seat tube. Would you be able to measure this? It is to see if there would be room for the EE Cycleworks dual mount brakes.
chaz
by chaz
Hi Guys,
On the topic of clearance, does anyone know if I would be able to fit ENVE SES 4.5 wheels on a Canyon Aeroad CF SLX M size?
djm
by djm
How wide are they?
My Aeroad has tons of clearance, really..
mudrii
by mudrii
chaz wrote:Hi Guys,
Will work perfectly as I already see many in the forum with the frame aeroad slx and wheels 4.5
