"True" BB30 cranks like the Sram Red Exogram with the integrated carbon spider have a shorter spindle than all 24mm cranks (Shimano, GXP etc) and some 30mm spindled cranks like FSA BB386 cranks and Rotor cranks. This is why Pren's question is a touch more nuanced than just finding the correct bottom bracket. Trying to fit a Sram Red BB30 exogram into BB30a is trying to fit two things together which weren't designed with each other in mind. This is why I tried to stress that it
might be doable but is in no way guaranteed.
goodboyr wrote:You will be fine. The difference is 5mm on the nds. If needed you can remove the threaded preload adjuster and use wave washers instead to make up the difference.
You will DEFINITELY have to remove the preload adjuster and even then due to the threading on the spindle it might mess up the fit with wave washers. Maybe you could grind the threads off to help but there ain't going to be too much space to play with. I'm not sure how deep into the preload adjuster the threads go.
Image of Sram Red BB30 crankset in my Cannondale CAAD9 frameset:
http://imgur.com/vZ6ebkD (probably includes a touch of parallax error)
