Bontrager aero brake calipers (rear)
TiboMadone
by TiboMadone
Hello, I have a 2014 Madone 5.9. I am happy with it except for the brakes. I have got the front caliper to work pretty well. I have read the instructions inside out and am aware of the small 2mm Allen key needed for the squareness of the pad movement towards the rim. But the rear set up leaves a lot to be desired. It is vague feeling and soft, with little vigour as far as caliper release goes. I understand that they are aerodynamic and light but are they really worth the effort? Can I change for sHimano 6810 rear caliper? I assume the Shimano is much heavier though. looks a lot more complicated.
Kayrehn
by Kayrehn
Yes use the shimano ones.
Ozrider
by Ozrider
What shifter levers are you using?
Ozrider - Western Australia
sub7kg
by sub7kg
TiboMadone wrote:Hello, I have a 2014 Madone 5.9. I am happy with it except for the brakes. I have got the front caliper to work pretty well. I have read the instructions inside out and am aware of the small 2mm Allen key needed for the squareness of the pad movement towards the rim. But the rear set up leaves a lot to be desired. It is vague feeling and soft, with little vigour as far as caliper release goes. I understand that they are aerodynamic and light but are they really worth the effort? Can I change for sHimano 6810 rear caliper? I assume the Shimano is much heavier though. looks a lot more complicated.
I ended up getting rid of my Madone, I couldn't ever make that brake work well (I was running campag too and they don't offer direct mount). The Ultra or DA direct mount are the best option without spending loads on EE brakes. I never succeeded in eliminating the friction from the brake cable through the frame. I was also limited by crank arm clearance with a Campag setup.
Kayrehn
by Kayrehn
I'm using dura ace brakes with campagnolo super record levers, it's pretty ok, not too bad.
spud
by spud
a few alternatives worth exploring - the FSA Direct mount brake, due out in 2-3 weeks, or the Tririg OmegaX. Both are roller cam brakes, with a potential advantage of not moving the lower housing when actuating.
truebeliever
by truebeliever
Im using sram red with shimano calipers, works great
stono38
by stono38
Bombtrager! hmmmm.
spud
by spud
Following up on this thread, I ended up getting the FSA direct mount brakes on my Madone 7 and I am very happy with the result - good feel, modulation, and braking power. Not the lightest set up in the world, but that's not even in the top 5 of my requirements.
spartan
by spartan
can you take some pictures of your madone with the fsa brakes
thanks
Current Rides:
2023 Tarmac SL7 Di2 9270
ex 2019 S-works SL6
ex 2018 Trek Madone SLR Disc
ex 2016 Giant TCRAdvanced Sl
ex 2012 Trek Madone7
audiojan
by audiojan
Doesn't the EE direct-mount brake fit the Madone? Those are some very impressive brakes. Great modulation and tons of stopping power.
spud
by spud
Yes, the EE brakes fit. But they require the pads be run close to the rim, which causes rub when out of the saddle.
spud
by spud
here's a pic of the rear brake installed. Hard to tell but I'm running 3-4 mm of pad clearance, so no rub
spud
by spud
another pic
frankenheimer
by frankenheimer
Hey any idea what those 5.9 brakes weighed when you removed them?
