Anyone have any idea how to route the cables on a Most Talon bar? There are 2 entry holes - one on inside and one on the outside of the bar - but both the shifter and brake lines exit from the inside of the bar. The outside entry point seems to be too extreme of an angle for the brake line but the inner entry point is too tight to run any housing. Thoughts?
PS - I literally cannot find anything online about these bars when it comes to running lines
Most Talon Handlebar Cable Routing
I have the exact same problem with my rear on my pinarello/most talon bar..
It dosent look right from above when you wrap the bar tape.. Any solutions?
This looks like the solution
http://www.cyclechat.net/threads/most-i ... ars.23736/
follow this example
follow this example
east3rd wrote:Anyone have any idea how to route the cables on a Most Talon bar? There are 2 entry holes - one on inside and one on the outside of the bar - but both the shifter and brake lines exit from the inside of the bar. The outside entry point seems to be too extreme of an angle for the brake line but the inner entry point is too tight to run any housing. Thoughts?
WHAT DID YOU DO???
