zipp 404 firecrest - Campy 11 speed to Shimano 11 speed
Nejmann
by Nejmann
Hey guys :-)
Can i change the body on this wheel with campagnolo 11 speed to a Shimano/sram 11 speed hub?
Best Regards Soeren.
Cheetahmk7
by Cheetahmk7
Just use your Campy 11 speed cassette. It will work fine.
Cosmo
by Cosmo
Only black or gray hubs can be made Shimano/SRAM 11. Silver hubs cannot.
after 2 drinks I'm a loser, after 3 a star
chayanat
by chayanat
+1 for Campy 11 speed cassette.
Slagter
by Slagter
Cheetahmk7 wrote:Just use your Campy 11 speed cassette. It will work fine.
True, but on the long run, that is a expensive solution. Campy cassettes cost twice the price as shimano cassettes.
Nejmann
by Nejmann
I run 9070 di2, and that cassette sure makes some crappy noises when climbing, so maybe a record cassette is better, and the price is the same?
Slagter
by Slagter
I ride 9070 as well. And I used to have a campy body on my Chris King hub racing wheels. When I switched to Shimano body and mounted a Shimano cassette, the noise desappeared.
lbs0927
by lbs0927
use Campy 11 speed cassette. It's any problem!!
Svetty
by Svetty
Another vote for just using a campy 11spd cassette. Chorus would be fine.
HTML
by HTML
Two more slightly cheaper options with Campagnolo splines are
Miche Primato Cassette Campagnolo 11 speed
and
BBB BCS-11C Cassette Campagnolo 11 speed
Cheetahmk7
by Cheetahmk7
A Shimano freehub costs around A$200, Ultegra cassette A$60 and a Chorus cassette A$120. The Shimano cassette option only becomes cheaper after the 4th cassette (5th if the OP already has one). I suspect most people would be unlikely to wear out just one cassette on their 404 as they only use them as race wheels.
Briscoelab
by Briscoelab
I mix and match Campy 11 and Shimano 11 on my various 11 speed bikes. No issues. Some are Di2 as well.
Is the Campy cassette old and you're using it on a new Shimano chain? That could be the noise issue.
Nejmann
by Nejmann
It was my old 9070 di2 (9000) cassette i meant, thats the one who is creaking. Just put on the chorus cassette on the zipps, and everything just works even with an old dura ace chain! So i'm happy. But should i go with a dura ace chain? or a campagnolo chain? When the cassette is campagnolo and the rest is di2 9070?
Slagter
by Slagter
^ old chain and new cassette is a really bad cocktail. Would you mind measuring the chain wear with a vernier? I wouldn't ride that combo if the chain is as little as 1/4 % worn.... Chorus cassettes are quite expensive.
Nejmann
by Nejmann
Slagter wrote:^ old chain and new cassette is a really bad cocktail. Would you mind measuring the chain wear with a vernier? I wouldn't ride that combo if the chain is as little as 1/4 % worn.... Chorus cassettes are quite expensive.
I don't attend to drive it that way :-) Just tried it on the work stand.
So my next question is - Dura Ace Chain or Campagnolo chain for NEW campy cassette and NEW dura ace chainrings on 9070 Di2 :-) ?
