I've been searching and haven't found an answer.
I am thinking about getting some Sram red 22 aerolink brake calipers. I have shimano 105 shift levers now. I found a great deal on some take off sram calipers. that would save me some weight.
Are the two compatible with each other?
sram red calipers compatible with 105 shift levers.
It never gets easier, you just go faster.
Technically yes, but the pull ratio isn't the same. It might feel a little weaker than if you used the correct calipers.
