Mortirolo gears
Run a Campagnolo 2011 Super Record 11 group set with 52/36 (TA Neruis Rings), Campagnolo now supply a 12/29 cassette.
Is a 12/29 compatible with a standard Super Record rear mech or do you need a longer mech, I gather you don't need to change your rear mech...though I'd ask.
Visiting Italian Alps again in June, riding Grandfondo Stelvio which includes the Mortirolo, I've ridden the Mortriolo before on a 52/36 11-27 needed 27 a lot! Was thinking a 29 would be a good idea just in case. It's a savage climb and lets face the last 3kms of the Stelvio are hellish. Plan to ride Tonale, Aprica, Bormia 2000 and Passo Gavia other days I'm there.
Also I gather a 52/36 12-29 will be slightly easier rather than change to 50/34 11-27? by my calculations.....think a 50/34 12-29 is not necessary and may spin too much
Thanks.
Thanks.
not 12km/h that's a good time
Well Contador used a 34x32 up his last Mortirolo climb and Ivan Basso in 2006 used a 36x26....very interesting differences!
But times have changed I guess 36x26 almost 10 years ago was considered normal up the Mortirolo
ok....I'm going for a 34x29:)
If you "spin too much" you can shift to a harder gear.
Other than a small amount of added weight, and larger gaps between gears, there's no drawback to having gears lower than you think you need.
And if you miscalculated or are having a bad day you may need them.
Thanks.
Yes it is.
bm0p700f wrote:How steep is this climb.
Steep enough...
http://www.hotelfunivia.it/varie/funivia_percorsi/bike%20climbs/3OK.pdf
I rented my bike when I visited Bormio which I think was running 34*30. I was glad about this when it came to riding the Mortirolo Gavia loop, as it was raining the morning I rode up the Mortirolo and had to ride most of it seated otherwise I would loose traction!
Dalai wrote:bm0p700f wrote:How steep is this climb.
Steep enough...
That is a monster
It only hurts if you think.
There is a difference between doing it on a certain gear and doing it with more comfort on a lower gear.
Especially if you're doing the normal tour Mortirolo - Gavia, then it's better to have a decent cadence because otherwise you will blow your legs and the next climb is even more hell.
I did both Mortirolo and Zoncolan on a 34*28. A 34*30 would have been better and maybe I could have gone faster with the 30.
