Campy Skeleton Brakes centre/fixing bolt - what thread size?
dadoflam08
by dadoflam08
Might seem a bit ridiculous but bike is not here and cannot find info on web anywhere - what is the thread on the fixing bolt for current skeleton brakes (M6?)
'83 De Rosa+'11 Baum Corretto+'08 BMC Pro Machine >6kg+'86 Pinarello Team +'72 Cinelli SC +'58 Bianchi+'71 Cinelli SC+'78 Masi GC+'83 La Redoute Motobecane+'94 Banesto Pegoretti+'88 Bianchi X4 +'48 Super Elliott+'99 Look Kg281+'18 Pegoretti
bangkok
by bangkok
Amazing ... no spec available anywhere. Dug up the spare alternate length bolts shipped with 2014 SuperRecord brakes ... M6 it is.
Attermann
by Attermann
bangkok
by bangkok
To clarify, I had assumed this item was the bolt for the main shaft that secures the brake assembly to the frame. The single mounting bolt one would tighten to hold the brakes in place on the front/rear forks. For example:
http://www.i-ride.co.uk/Campagnolo-BR-R ... 185mm.aspx
dadoflam08
by dadoflam08
Thanks Bangkok that's very helpful - just what I was after. I agree it is really surprising that you can't readily find out that sort of info.
