Trek Emonda ALR (aluminium version)
Yes thank you Disc Jockey Connel.
- Tinker, Taylor, Tart
Same geo as the rest of the Emonda H2 geo.
I love cheap, solid and aggressive aluminum crit bikes. This doesn't have that flair.
Given the strong dollar at the moment, I'd say you should expect to pay close to MSRP (RRP).
Madone 9 - https://bit.ly/2Nqedbn
Emonda SLR - https://bit.ly/2UK5FP8
Crockett - https://bit.ly/2Xem4sk
"Grinder and paint makes me the welder I ain't"
LaundryHamper wrote:"Grinder and paint makes me the welder I ain't"
huh?
but talkin' of paint, it says the frame is 1050g unpainted, does that mean anondized or before being anondized?
any of you fellahs who work in the shops had a chance to weigh up this framset.
bigfatty wrote:LaundryHamper wrote:"Grinder and paint makes me the welder I ain't"
huh?
Smoothed welds look great, but you can't actually tell that they're of any real quality - you can grind down a sloppy weld and have it look just as nice as a great one would if it were ground down.
I guess it saves some weight though, and Trek's welding probably isn't bad, but grinding down welds is traditionally a novice's trick for hiding mess-ups.
I've weighed a ALR 6 in size 52, 7.78kg. Pretty decent weight if you take in mind those Bontrager Race wheels weigh +1800 grams.
US pricing: $989.99 for the frameset, $1759.99 for the 5 (105 build), and $2249.99 for the 6 (Ultegra). Looks like they've gone right in line with the 'equivalent' CAAD10 build. Whatever you think about Trek/the Emonda, I'm loving the fact that the big brands are taking alu seriously again - just going to mean more and better budget weenie options down the line.
CAAD10
Allez E5 Smartweld
Emonda ALR
Propel SLR aluminum
Lots of great options available.
Allez E5 Smartweld
Emonda ALR
Propel SLR aluminum
Emonda ALR aluminum YouTube video: https://youtu.be/_7J4-G2QxX8
ALL-NEW TREK EMONDA ALR TAKES LIGHTWEIGHT FRAME TECH TO ALLOY MODELS
http://www.bikerumor.com/2015/05/13/all ... oy-models/
Unpainted size 56 is 1050g and painted fork is 358g with 240mm steerer.
