Rotor 3D + crank
Crank compatability is a nightmare. Was considering a weenie frame like an R5 or Vial evo D as I now have my non S-works Tarmac under 6kg, but there seems to be no way to fit my BB30 S-works crankset which I'm perfectly happy with (at around 520g with spider and rings) to either frame as I believe they have a wider BB. Buying a new set of cranks seems excessive...
DCnoJ wrote:stormur wrote:But not even a word about BB30A
They're both compatible with BB30A. I just ordered one for a 2016 Cannondale Evo. Instead of using the standard 11.5mm cone spacer on the non-drive side, it requires any combination of spacers totaling 6.5mm.
Sorry - which BB have you gone for for the 2016 evo?
Am about to start a 2015 evo hi-mod build with a 3D+ crank - any BB recommendations? Thanks!
OJ wrote:Oh yeah! Another new learning opportunity on BB's and different standards. The Cervelo version of the spider/lockring will not fit anything but BBright. I need a new spider and a lockring. And of course...I will need a lockring tool as well and the piece seems to cost $60...Bloody hell with these!
I am close to ordering Ultegra crankset and just use regular bb86 BB on this thing. Tooling, new lockring and spider will cost almost the same as the Ultegra crankset.
Technically incorrect.. A Cervelo specced Rotor crank will fit a BB/Pf30 set up..provided you install it with a 11mm NDS spacer
2015 FELT AR1 TeXreme! http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134989
newforker wrote:OJ wrote:Oh yeah! Another new learning opportunity on BB's and different standards. The Cervelo version of the spider/lockring will not fit anything but BBright. I need a new spider and a lockring. And of course...I will need a lockring tool as well and the piece seems to cost $60...Bloody hell with these!
Perfect reply for me - I'm collecting my PF30 frame (non Cervelo) tomorrow, and have a nice set of 3D+ (BBright) cranks to fit.
I also have the Rotor 4630 BB arriving (I'm sure it's arrived a few days back).
If I have the time, I'll bring both to the shop, and discuss the fit & spacers with them.
Look 695 aerolight eTap 11
Boardman TTE eTap 11
Brompton S2 LX ti custom
Trek 5500 1994 Sram Red 10
Boardman CXR9.8 eTap 11
Open UPPER - DA 9270
Ridley x-fire Sram Red 10
and lots of non- WW others.
I managed to fit the following fine:
- Rotor 4630 BB
- Rotor 3D+ off a Cervelo R3
into my PF30 (Boardman CXR9. frameset.
I confess I got the mechanic at my LBS to fit the BB (he offered!). The other stuff went straight on, including the two standard conical washers that came with the chainset.
- Rotor 4630 BB
