BB30A vs Campagnolo
stormur
by stormur
Cannondale had (again) brilliant idea to announce new bb standard : BB30A(symmetric) … There's few ways to install on it Shimano/Rotor cranks, at least 1 way for GXP, 1 good for BB386Evo. Real problem starts at Campagnolo non-PowerTorque.
I'm "studying" possible solutions already 17th hour (!), and except machining left UT BB30 left cup there's no way to instal UT crank in BB30A bottom bracket :(
I didn't research yet deeply OverTorque, but seems to be even bigger mess.
Same doubts about Rotor UBB30 crank ( is it EXACTLY bb386 evo standard crank? ) .
As usually, more I know more doubts I have … so maybe someone found the way ?
Does really choice of cranks for Campa users narrowed to BB386, Rotor 3d24 and Campagnolo PowerTorque ???
Sure, Hollowgram fits. I know. But -imagine- I don't want Cannondale crank ;)
Mark Twain
bikerjulio
by bikerjulio
OT will fit, you just need to change the 9mm Campy spacer for a 4mm spacer stack.
UT will fit using Wheels adapters, but you'd have to machine 5mm off the shoulder of NDS one so it sits that much further into the frame.
There's sometimes a buggy.
One.
stormur
by stormur
First UT : how you see milling 5mills of shoulders of WheelsMfg adapter ? Just don't see it ( not enough material :( )
2nd is much more interesting :thumbup: have to make my research :idea: is it has been done by anyone ? still works ?
This Athena is NOT overT … it's Pshopped…
Athena (triple) is regular PT with BB30A cups ( yes, Campy did that for Cannondale ;) )
Mark Twain
bikerjulio
by bikerjulio
The Wheels adapter just needs to have 5mm taken off the "outside", in other words the tapered part. How hard could that be?
And as for OT it's almost a straight fit with a spacer change on the NDS.
One.
stormur
by stormur
And if you cut off "outside" of adapter , then bearings will go further/ deeper ? still can't see it. Guy who milled BB30 cup (nds) , milled cup INSIDE as well- that's point of "conversion" - here I do not see enough od material to do it.
Even had to machine bit more, so make a room for spacer , cause weavy waher had'nt enough support.
OverTorque : do you have some image of installed OT crank on BB30A ?
Spending 800€ for something " it should work" will be ridiculous… ( crank, bb, tools ).
Mark Twain
bikerjulio
by bikerjulio
Fitting OT is just common sense surely - it's a BB386 EVO system.
For UT if you lose the Campy bearing, and modify the adapter, you still have the BB30 bearing on the NDS
One.
stormur
by stormur
386 evo is 30mm to 86mm symmetric shell, bb30a is 73mm asy …
Simply can't find succesfully done OT on BB30a :( .
Mark Twain
thisisatest
by thisisatest
Overtorque has spacers between the arms and bearings. For bb30a, use a 5mm shorter spacer on the left side. It really is that simple.
stormur
by stormur
Theoretically : Yes. But as previously : 1 image saying someone did it successfully ?
I have othe rbrilliant ( at least in theory ) ideas for UT f.e. - but until I'll test it in real life , I don't know how it work.
Mark Twain
kervelo
by kervelo
What is the current status of the Campagnolo UT and BB30A compatibility? Are there any new experiences of fitting them together?
I noticed that at least bbinfinite has a product that is supposed to make them fit.
http://www.bbinfinite.com/products/bb3a ... campagnolo
kervelo
by kervelo
Seems that there is another product for marrying BB30A and Campagnolo UT: Wishbone makes a special bottom bracket BB30A25C.
http://wishbonetw.com/product-1.php?id=31
The product looks good.
Googled frantically, but did not find any stores selling Wishbone products: any ideas for a seller?
sugarkane
by sugarkane
kervelo wrote:Seems that there is another product for marrying BB30A and Campagnolo UT: Wishbone makes a special bottom bracket BB30A25C.
i got one in australia.. wishbones thread fit 82.5 stuff is F'ing genius
qorwlch
by qorwlch
wow.... bb30a diff
:x
kervelo
by kervelo
Ordered the Wishbone BB30A25C bottom bracket from the ebay. Chose the product over bbinfinite just because it can be removed more easily if ever needed.
