Continuous or Interrupted Disc Brake Cable Housing?
Valbrona
by Valbrona
Rear brake cable goes through the top tube and I can use internal stops or drill them out to allow a continuous cable run.
What would your preference be?
Thanks folks.
mattr
by mattr
Benefits to both.
Interrupted gives you less compression over the length of the cable run. (Top tubes don't compress noticeably)
Continuous has "less" risk of dirt causing problems.
Personally I'd use the internal stops and get a sharper brake feel. But it depends on what the bike is. Hack, cross, commuter........
ITTY
by ITTY
If it's a bike that will be used in nasty cross races, I'd go with the continuous run. It's really annoying to replace cables/housing multiple times during a cross season due to contamination. Otherwise I'd stick with the interrupted.
Moloko Plus 6.24 kg
"We haven't located us yet"
MattSoutherden
by MattSoutherden
Sealed cables like Gore/Jagwire Elite/etc. Best of both worlds.
Snacking on carrot sticks - Where did it all go so wrong?
Finsbury Park CC
bm0p700f
by bm0p700f
Well i use whatever the bike is designed for it does not make much difference.
deek
by deek
I'd worry about the housing rattling against the top tube if you drill out the stops.
Svetty
by Svetty
That Cannondale will be just fine using the interrupted stops - mine is :D
