Cannondale Slice RS Black - Installing Di2?
shinkansen
by shinkansen
I picked up a 2013 Cannondale Slice RS Black with Red installed and have a 9070 Di2 groupset (internal battery)... Can anyone give me some advice on installing Di2 on a Slice RS? I'm guessing my only option is to use an external battery mounted below the BB?
I've got the derailleurs, bar end shifters (not planning to use shifter/brake combo), internal junction box, 3-port junction box, and internal battery (Bought all this before the RS thinking I'd be doing an internal install :roll: )
NiFTY
by NiFTY
Internal won't fit anywhere, as you have worked out. Why not run a shifter/brakes? I only got di2 for my TT as I thought have shifter/brakes made sense when coming out of the gate/corners etc.
Raineman
by Raineman
Looks like Cannondale-Garmin use an external battery on the downtube
I would look at the holes in the frame and see if the battery will fit/can be wedged in any of them (the seat tube looks promising if you can get the battery in there). The only other possibily I can think of is putting it in the extensions if you really want it to be internal.
shinkansen
by shinkansen
I ended up just using the standard external short mount under the BB.
