Easiest clincher road tyres to mount (tubeless compatible ri
Dman
by Dman
Hi,
I'd appreciate some advice. I've got some new tubeless compatible AX carbon clinchers and for the life of me I can't fit my favorite clincher tyres (Panaracer Type A 23c). Traditionally they are hard as they have a very tight bead.
I pre-stretched them on a H Plus Son rim to 150psi first but still not even close with someone helping and 4 tyre levers at play. Next step will be a hairdryer to warm the tyre first [emoji16]
So, what are the softest clincher tyres? I'm thinking GP4000s are worth a go next.
Not that interested in tubeless tyres yet but that might change....
The more I ride, the less I spend
bm0p700f
by bm0p700f
Gp4000s tyres are quite easy to fit to most rims but it epends on the rims and your tyrefittin technique. Do you case the slack around the rim by any chance. If ot learn how to do this.
showdown
by showdown
I had the same problem with a set of Vittoria Open Corsa tires on a set of Ultegra tubeless-compatible rims. Switching to the GP 4000S II solved the problem. Still takes a bit of effort but nothing out of the ordinary.
Dman
by Dman
Thanks for the tips. I'll try them next
hdk
by hdk
IF you decide to go the tubeless route, I was able to easily mount Schwalbe Ultremo ZX tires on my Campagnolo Shamal rims.
Harmitc
by Harmitc
I've found Challenge, Vittoria & Continental to be pretty easy to mount/dismount. Only other one I've attempted to remove was a Panaracer pre fitted to a wheel I bought. Almost cut it off it was so tight.
Dman
by Dman
GP4000s mounted. They are infinitely easier to mount than anything else [THUMBS UP SIGN]
liam7020
by liam7020
Mounted a pair of Michelin Pro 4 Service Course on a set of tubeless compatible carbon clinchers with little problem. However the Pro 4s felt like I was riding through treacle - only used them cos I got one free and the other one cheap. Anyhow riding them was a miserable experience and they had to come off. Reverted to my absolute favourite clincher tyre - Veloflex Corsa. Well now, putting the Veloflex on the tubeless clinchers rims was defo the biggest tyre fitting struggle I've had in 30+ years of riding bikes! Even more difficult than fitting tyres to Campag Neutron wheels and that's saying something!!
Of course with the Veloflex the ride quality is now sublime but I dread getting a roadside puncture......
Tarmac SL6 & Campag Record EPS https://weightweenies.starbike.com/foru ... 0&t=153968
Dman
by Dman
I'll try Veloflex next! Love the tubulars
Smallring
by Smallring
I gave up and went for tubeless tires after pinching few tubes trying to mount Michelin Pro 4 Race to Ultegra wheels. It was a nightmare. Imagine if you got a flat on the road and need to change tubes?
Dman
by Dman
I'm on team GP4000s now. Easy to mount and remount later
