Nejmann
by Nejmann on Tue Apr 14, 2015 6:55 pm
TonyM wrote:You could also go for the Campagnolo Hyperon Clincher...But the weight is not attractive compared to the Bora35 Ultra (1345g vs. 1370g Bora 35 Ultra)
And even less attractive to the possible Gipfelstrum clincher which could be 1025g + extra 80 g for the clincher version so in total 1105 g
I would also buy these immediately
On the other side which advantages would these Gipfelstrum have compared to the Meilenstein ? the lower height of the Gipfelsturm rim bring less crosswind effect, right ? Is there any other adavantages ?
I have a pair of alu clincher for the mountains (Fulcrum Racing Zero nite - 1420g) and I have just ordered a pair of LW Meilenstein SchwarzED Clincher 1180g for the hilly region where I also live.
My search for a real mountain wheelset which should be very light and excellent/ safe in braking in the mountains is not that easy.
I have skipped the AX Lightness Clincher due to their average reviews (braking issues) and as they don't have ceramic bearings (surely a mental advantage).
This mountain wheelset should be better than my current set of Fulcrum Racing Zero Nite Clincher and my LW Meilenstein Clincher
How is the breaking surface on the nite? Still black?
TonyM
by TonyM on Thu Apr 16, 2015 8:37 am
drmarg wrote:
Tony,
The Gipfelsturms are available as clinchers? I could not find these on their website??? This would be one great climber set!!! I currently run the AX Ultra 24 tubulars. No issues.....
Unfortunately not as Clincher available
That was only my calculation on the weight if available....
Gesendet von iPhone mit Tapatalk
TonyM
by TonyM on Thu Apr 16, 2015 8:38 am
The whole rim is not black but dark grey.
CEVelo
by CEVelo on Sun Apr 26, 2015 10:18 pm
Yeah, will change the stem when I have the fit dialed 100%.
Its funny, per the online geometry chart, I though I needed a 100mm stem, turned out in real life i needed a 120mm to match my S3 setup. Guess things like 'reach' and 'stack' is all relative and not 100% consistent between brands. In this case it turned out in my favor, as I much rather run a 120mm stem.
Bike is awesome, just did 50miles/5000ft on it. Love the bike and especially the DA DI2 group, hard to think ill ever want anything else. Can't wait to ride it more, yet have a lingering headcold i need get rid of first.
drmarg
by drmarg on Mon Apr 27, 2015 2:54 am
Really beautiful! Again, congratulations! Looks fast! I like the Italian stem on this bike. The little bit of red sets it off. Are you running the stem up or down? Hard to tell in the image. It almost looks like a 90 degree stem? Looking forward to more comments on the road feel of this frame, bump compliance, etc. Don't even need to ask about torsional rigidity… Feel better!
2015 TREK Emonda Project One 6.03kg
2015 TREK Emonda Project One 5.44kg
2014 BMC TeamElite 01 MTB 9.07kg
CEVelo
by CEVelo on Mon Apr 27, 2015 3:36 am
Stem is -6degrees, riding it down. Agree, fork angle makes it look a bit odd.
From my 50mile/5k ft climbing today ride, it leaves nothing to wish for. Initial impressions are that the bike is VERY responsive, nicely compliant and tracks very steadily. Easy to spin up to speed, maintain speed and a very capable climber and great to descend. Obviously I will need another several hundred miles before I can tell in more detail and with a more critical view. The setups as shown weight in on 15.2lbs, so I could only imagine what a set of low weight / climbing tubulars would do for its uphill capability.
Very Happy!!
mimason
by mimason on Mon Apr 27, 2015 6:18 pm
Glad to hear that you are happy so far. Your first impressions are in line with what I experienced. I had to play with stem height to get the handling the way I wanted it and I'm actually much lower than previously with no comfort issues. Long and low and aero! I actually find myself in the drops a lot on fast flats and group riding.
Interesting how you were 20mm off in your measurements. You're lucky it wasn't in the other direction since a lot of people buy too big a frame coming from other geometries.
ALS
by ALS on Mon Apr 27, 2015 7:32 pm
The bike looks great glad you're enjoying it. Picked up mine last week exact same issue..maths said 10cm stem but I need at least 11cm
CEVelo
by CEVelo on Tue Apr 28, 2015 5:38 am
Size 54 (55cm top tube).
Fit me spot on, but be aware, the online stack and reach chart seem off (esp. reach as I could use a 20mm longer stem than predicted)
Cheetahmk7
by Cheetahmk7 on Tue Apr 28, 2015 5:47 am
bdb wrote:I have the C60, it replaced a CX-1 and I can tell you it is very comfortable for long rides, I've seen a lot more F8's around Marin/SF than C60's, maybe because abovecategory have a good customer base here and sell quite a few of them.
Last weekend I saw 4 of them. So even if you debadged it, it's very recognizable. And it's grown on me a lot.
Latest build from AC.
https://instagram.com/p/0mDQYLBRNu/?tak ... vecategoryI have yet to get a ride on one, but I feel like either bike will fit the bill.
How does the C60 compare to the CX-1? The reason I ask is because I had a CX-1 and found that it descended really well but gave a really harsh ride and was pretty heavy too.
Cheetahmk7 on Tue Apr 28, 2015 7:32 am, edited 1 time in total.
