What stems have low (3.5cm) steerer clamp bit?
User Name
by User Name
It's for a friend; I don't care about stuff like this. :thumbup:
Standard is 40mm, but some are 35mm
All I know of so far is some old ITMs and some Cinellis (Solido, for eg)
Thanks
kkibbler
by kkibbler
Someone in the gallery has a Basso Diamente with a really low stack height stem.
User Name
by User Name
Thanks. I assume it's a Basso stem, like this
bmCube
by bmCube
Syntace flat force has a clamp stack of 25mm
Rotor s3x has a clamp stack of 34mm
bfno
by bfno
FSA make a -20 that has a low stack that is designed for MTB but theres nothing stopping you.
Venge | Shiv TT | Langster | Dogma 60.1 | CruX | Aeroad CF SLX (WIP)
jekyll man
by jekyll man
I don't think there's a "standard" as such, just some that seem similar.
The Ritchey 4axis are fairly shallow, as is an old Massi one i have with a flip front.
Don't have either at hand to measure them though
Official cafe stop tester
Stolichnaya
by Stolichnaya
If your friend is willing to go with 26.0 bars, then he might find some low stack height stems to go with them. Things seemed to be slimmer all around for the most part with the 26.0 standard.
TomHelly
by TomHelly
Thomson X2 is fairly low and has good angle options
wheelsONfire
by wheelsONfire
User Name wrote:It's for a friend; I don't care about stuff like this. :thumbup:
Thanks
Yes, it's true, i have two S3X stems and they are 34mm stack height and also very light.
Bikes:
Open *UP* (2016.04.14)
Zitter
by Zitter
Briscoelab
by Briscoelab
Thomson X2 is really low stack for a modern stem. The Flat Force is also low, but the amount of drop and odd lengths might not be idea on a road bike.
User Name
by User Name
Thanks for the replies. All suggestions have been forwarded on. :D
He's got an X2 on another bike, but has had problems with the bars slipping (rotating), so he's not overly keen to get another one
VTBike
by VTBike
Deda Superleggero. Super low stack height. Great stem.
Briscoelab
by Briscoelab
A bit of friction paste and proper torque will usually fix issues with an X2.
