Zipp 303FC tubular vs 202FC clincher
CBRE
by CBRE
I have both of these, I feel the 202 with Cont gp4000s/latex tubes is stiffer and quite fast but the 303FC tubular with Vittoria CX's are a bit lighter an ride nicer. Around here most races are roughly 50m with 4000ft of climbing. What it comes down to is which is actually more aero and less rolling resistance?
Curt Brown
2016 Cannondale EVO Etap 13.8#'s
2012 Cannondale Supersix EVO etap 13.7#'s
2017 Cannondale SUPER X Force 16.0#'s
2016 Cannondale FatCad2 28.1#'s
2011 Cannondale Carbon Flash 1 17.9#'s
goodboyr
by goodboyr
303 tubbie is more aero.....202FC clincher has less rolling resistance.
em3
by em3
...comparing rims only (not taking tire profile into consideration) the 303FC is definitely more aero then the 202 (per Zipp tests), but rolling resistance is tied more closely to tire choice (tubulars) and tire/tube choice (clinchers) as well as the width of the rim bed (tubulars) and inner bead to bead width (clincher). If you dump the Continental clinchers and exchange with Veloflex of Vittoria high TPI tire with your latex tubes, you will be hard pressed to tell a difference between tubular and clincher road feel (expect on corning performance, where ur tubulars will be notably better) and you might yield identical rolling resistance values.
In the end u need to go with what YOU feel is faster not with what the the tests indicate might be faster....afterall, u r splitting hairs on potential marginal gains.
______________
CBRE
by CBRE
Was thinking the 202FC w/Gp4000s is equal in aero vs the 303FC w/tubi, can't find any good data on aero testing with Zipps and tubular tires. The 303's are my go to race set for crits and or short hilly races.
Curt Brown
em3
by em3
I'm curious, what is the rationale you are using? Why/How would potential aero effect differ for tubular vs. clincher, on either wheel (assuming they are the same width)?
______________
CBRE
by CBRE
em3 wrote:I'm curious, what is the rationale you are using? Why/How would potential aero effect differ for tubular vs. clincher, on either wheel (assuming they are the same width)?
Couple of examples of aero of tire testing, all clincher, I have no available data for tubulars:
http://flocycling.blogspot.com/2013/04/ ... sults.html
http://speedtheory.co.nz/marginal-gains ... -part-two/
Curt Brown
em3
by em3
...intersting data, but I didn't catch the tubular v. clincher differentiation. More importantly, there is no such thing as a standard width 23c tire (or any width for that matter). A Conti 23 will measure closer to a 25 and have a much taller profile then any of the tires tested by FLO. The Vitt will be closer true to size 23 with a much lower profile, and the MIch will be closer to 25 with a mid profile. My point is that the test didn't bother to measure tire width/profile differences. In fact, what the test might be showing is that a high profile tire whose actual measured width is 25 (i.e. 23c Conti) might be the most aero choice for the specific Flo wheels specs....whether the same can be duplicated across different manufacturer's wheel design is another issue.
______________
CBRE
by CBRE
It is all confusing and I haven't been able to do a accurate comparison due to wind variations and fatigue level.
Curt Brown
myungjinkim
by myungjinkim
Price, weight, and performance all 303 Tubular recommendation.
teokim
by teokim
Moer over, 303 figure is better
jimborello
by jimborello
I own both, Im trying to sell the 202 clincher because I cant justify it over the 303 tubular. The 303 looks better, it is more aero, weighs less, and has that tubular feel the 202 doesnt. And one more factor; it tolerates better braking heat than the 202 so it is safer.
