CAAD 10 problem
Gardengnome
by Gardengnome
Hi
I have put 25 mm tyres on my CAAD 10 and it keeps catching the brake calipers on the highest point of the tyre. Has anyone else had this problem?
MisterMuncher
by MisterMuncher
No problem with 6800 calipers and Schwalbe One 25s. What tyre/caliper are you running?
Frankie - B
Admin - In the industry
by Frankie - B
What wheels/ rims do you use? Wider rims make the tires stand taller.
If you want to see 'meh' content of me and my bike you can follow my life in pictures here!
Gardengnome
by Gardengnome
running conti gp 4000s 25mm and sram red calipers. wheelsmith race 24mm wide clincher
hmai18
by hmai18
Really? I'm running the older-style Red calipers, Pacenti SL23s with Schwalbe One 25mm tires and have oodles of room.
Gardengnome
by Gardengnome
i'll take a photo there is like 0.5mm to the tension springs and it catches it places
btompkins0112
by btompkins0112
Yep....I had that problem with 4 season 25s and Force 22 brakes on my CAAD10. I was running XC279 rims.
GT56
by GT56
contis are the highest tires one can find, contrary to michelin
ninjanoir78
by ninjanoir78
Conti 25 are more like 27
Ninja
Couse1986
by Couse1986
it's digusting that cannondale just ignore all the problems that are having, why should people try and fix it themselves when the problem is with their product, a lot of people are having creaky BBs on dales and yet bike magazines/websites still give them good reviews.
mattyNorm
by mattyNorm
It's called crack and fail for a reason ;)
MisterMuncher
by MisterMuncher
Couse1986 wrote:it's digusting that cannondale just ignore all the problems that are having, why should people try and fix it themselves when the problem is with their product, a lot of people are having creaky BBs on dales and yet bike magazines/websites still give them good reviews.
The problem here is the caliper clearance, not the frame. It's arguably not even a problem, as it's only very recently "racing" bikes considered clearance for more than 23mm tyres, and the CAAD was designed before the recent crop of wider rims.
ChrisSnyder
by ChrisSnyder
A teammate of mine had the same problem with campy brakes while another friend with the same brakes and frame size had zero issues.
Alchemy Custom
8.3kg - Not so WW
roadieboy
by roadieboy
I used Panaracer 28's on narrow Mavic wheels on my CAAD10, they worked OK. If I rode through thick mud with that setup, I'd get some noise from the front... didn't bother me enough to change the tires until they wore out though.
