BB of Isaac Proton FW - 42mm shell?
Hi,
I have a problem with BB (currently I have Shimano SM-BB91-42) in my frameset Isaac Proton FW. I want to install Dura Ace 7900 crankset, but the axle is too short (or mounted BB is too wide). I press cups to the end. Maybe I must apply another bottom bracket?
Here are dimensions of shell in the frame:
Another pictures:
If someone can help me, I will be very grateful.
Another pictures:
sorry, i am not well informed with this bb-stuff, but could those possibly fit?
http://www.bike24.de/1.php?content=8;na ... 413;lang=2
- bikerjulio
I'm not a Shimano person but i have studied BB's.
Is that a MTB BB by any chance? It appears to be. Therefore for 5 mm wider cranksets.
I see that Isaac describe the BB as "BB Shell Hybrid: Integrated Shimano Press Fit". Completely meaningless and misleading. Shimano BB86 uses a 41mm ID shell standard.
Perhaps ask Isaac?
Perhaps ask Isaac?
There's sometimes a buggy.
One.
One.
this is my suspicion as well (bit i did not have the guts to state it )
when i "google" "sm bb9142" i get this:
http://www.bike24.de/1.php?content=8;na ... 164;lang=2
- bikerjulio
I'm pretty sure that's a MTB BB.
That is a very unusual (Unique?) BB shell you have there. Does not fit any of the common types. See here
http://www.lightningbikes.com/cranks/bottom-bracket-shells.html
It's closest to a direct bearing fit BB386 EVO system, where instead of using PF30 cups, the bearings are pressed in directly to the frame.
This needs to be done very carefully, using the correct loctite and procedures.
To fit a Shimano style crank would then just need bushing adapters to get the bearing ID from 30 mm down to 24 mm. Wheels make the adapters - just a plastic bushing. http://wheelsmfg.com/386evo-adapter-for-shimano-cranks.html
I guess as an alternative you could try machining back the shoulder on those BB's you have already to allow them to sit more deeply. 2.5 mm off each side will do it. If I was in your shoes I would try that first.
There is yet a third possibility. The only difference between your shell and a standard BB 86 is that yours is 42 mm ID and the standard is 41 mm. If Isaac or anyone else can provide a sleeve that will get the ID down to 41 mm, then a completely standard Shimano BB86/91 road bottom bracket can be used.
One.
One.
You may well find that if you tap one of the cups out, then pull out the plastic centre sleeve, then press both cups fully home, that they'll fit flush against the BB shell, and you can fit the crankset successfully. As far as I recall, it's the width of that centre sleeve that is the difference between the road and mtb bottom brackets, the cups themselves are the same fit. The sleeve may stop some water getting on the axle, but a smear of grease on it will stop any corrosion setting in.
Hope this helps!
Hope this helps!
- bikerjulio
That is a shoulder on the cup. They won't go in any further without removing it.
One.
One.
- bikerjulio
It's a MTB BB. The spacer is used on MTB cranksets, but the lack of it will not fix the situation. The BB is 5 mm too wide for a road crank even without the spacer.
One.
One.
- jekyll man
I can't see that the problem is the frame/BB.
With a total width of approx 80mm there should still be enough spindle sticking through, otherwise how would it fit bb86/90?
Maybe check to see if you have a strug chainset?
Official cafe stop tester
- bikerjulio
The description for that BB is
Means Shimano MTB cranksets, not road cranksets though.
So this, plus the OP leads me to believe that the BB shell is 42 mm ID.
Since Isaac refer to it as "Shimano pressfit" it should be 41 mm ID but apparently isn't.
Unless OP has managed to press a 42mm cup into a 41mm hole
Perhaps Isaac normally supply a sleeve? Nothing useful on their site.
High-quality Pressfit bottom bracket cups. Easy to install, increased durability because of the larger bearing size. Pressfit 91 bottom bracket cups can be used with BB30 MTB frames (bottom bracket size 84,5x42mm) only. All Shimano Hollowtech-II cranksets with integrated 24mm spindle are compatible with this bottom bracket.
One.
One.
- Frankie - B
- Admin - In the industry
Hold your horses with speculating...
I've had the Proton version of this frame. you have the Proton Flyweight at hand. There is a shoulder inside the BB like on your drawing. It could be that there must be pressed two special rings against those shoulders. Then you press in a BB30 bearing and then follow up with the correct spacer for shimano. Let me run into the garage as I remember I have kept the box of the BB adapter.
If you want to see 'meh' content of me and my bike you can follow my life in pictures here!'Tape was made to wrap your GF's gifts, NOT hold a freakin tire on.'
- Frankie - B
The adapter that was delivered with the frame was called System 42. I'd suggest that you contact Isaac directly.
Thank you for your interest.
Yes, now I have exactly this BB:
It's for mtb, but probably Shimano doesn't produce 42mm BB for road.
I'm sure that shell in frame have 42mm, becouse I've tried with 41 and were too small.
I wrote twice to the company Isaac, but they haven't responded.
Bikerjulio have great idea with machining back of those BB. I need to try do this.
Another option is buying 42mm bearings and adapters, but I'm worried that I will give money and it will not fit again.
