crossing cables
^+1 internets for you
bura wrote:@tinchy: no problem mate.
@kode54: suggestion made was meant to keep cables slightly away from DT. Not to keep them away from touching each other.No issue with friction of cables.
distance to DT is about the same as compared to straight cable feeds versus crossed ones. on bumps...there's no cable slap if that's what you're worried about.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
@HillRPete
Yes novel idea indeed.
I've decided to buy this http://www.tweekscycles.com/components/frame-protection/lizard-skins-clear-downtube-protector as the cable rubbing the downtube is not impacting on shifting performance, or at least if it is it is being compensated for by the smoother routing out front - my only concern is the paint and so this will cover me on that.
Next time I think I'l just route parallel but hey ho, you live and learn.
Thanks all who contributed.
Never done this and always wondered about it. Will try it the next time I re-cable.
Alchemy Custom
8.3kg - Not so WW
8.3kg - Not so WW
tinchy wrote:@HillRPete
i just get scraps from a place that does clear film for cars. same stuff. goes on glossy, but doesn't matter. you get for free if you ask nicely.
- Factor LS Disc
- Factor LS Disc
Campagnolo says "do not cross cables under/ in the DT" ( what means also crossing housing around HT ) . I did it Works fine. Even better than fine.
Mark Twain
I can be wrong, and have plenty of examples for that
Mark Twain
