FSA SL-K Light Crankset - Swapping between BB86 & MegaExo BB
syncmaster
by syncmaster
I'm getting a new frame that uses a BB86 bottom bracket standard. My current frame uses an English 68mm BB, so with my FSA SL-K Light crankset it uses the MegaExo bottom bracket. If I buy this FSA BB86 bottom bracket: http://www.backcountry.com/fsa-steel-bo ... -bb86-bb92
Will I be able to use my cranks with that BB on my new frame?
Thanks for any help
Attermann
by Attermann
syncmaster
by syncmaster
Any reason why the one I found won't work?
Jesper64
by Jesper64
No, they're both the same bottom bracket and will work.
Attermann
by Attermann
When i read about it, there is a version for Carbon crankset, and aluminium crankset, but it could be due to fact that the one i linkes to has got better bearings and are made out of aluminium
Jesper64
by Jesper64
Yeah I don't quite get why they recommend a different one for carbon cranks. Give FSA an email and double check.
MisterMuncher
by MisterMuncher
IIRC, there's actually 3 FSA MegaExo standards, a 19mm spindle version for the Omega crank, a 24 mm with the same measurements as Hollowtech II for the mid range cranks and then a 24 mm that's slightly different for the SL-K, K-Force and non-compact versions of the Energy crank.
