dha
by dha on Wed Jun 10, 2015 9:16 am
MiddMan wrote:How is the braking on these? Also, is there risk of overheating? I have some pretty steep (and sometimes sketchy) long descents where I live and I'm curious if anyone has really pushed these on hilly or more preferably mountainous terrain?
Not ridden in the mountains with them so can't comment on that. But braking on steep descents is sharp and you get an immediate feeling of slowing down and the feel is consistent througout the pull on the lever. (DA9000). Am happy with how they brake, they feel in my mind more responsive in the initial bite compared to my zipp 202s.
I haven't ridden them in the wet however so can't comment on that.
Timujin
Timujin
by Timujin on Wed Jun 10, 2015 9:56 pm
Dogmatic13 wrote:I've finally gotten my 2015 Bora One 50 Clinchers and will pair them onto a C60. Before purchasing the wheel set I dropped Colnago a note and got a reply back saying that the Bora clinchers should clear fine. I know the tubs clear, and I'm hoping the clinchers are ok too.
To be safe though, I may go with my usual Conti GP4Ks II in 23mms first. For the experts there - I suppose using 23mms on a 24mm wide rim is ok right?
Hey. Did your clinchers come with rim tape?? Got mine today, no rim tape in the box and they are clinchers as I just fit the tyres/tubes on
Timujin
by Timujin on Thu Jun 11, 2015 7:07 am
nlouthan wrote:There aren't any spoke holes, right? No rim strips needed. I don't run rim strips in my Shamals.
correcto, no holes... so this is new to me haha... the finish is sublime.. the finishing is awesome, the little holder for the valve is handy to stop the rattle (and removes the plastic tape scenario)
by kgt on Thu Jun 11, 2015 8:50 am
Campagnolo skewers are the most powerful but you can gain 130-140gr using something lighter.
Campagnolo should consider redesign these someday. Ti axle and carbon levers would be great.
Timujin
by Timujin on Thu Jun 11, 2015 9:00 am
kgt wrote:Campagnolo skewers are the most powerful but you can gain 130-140gr using something lighter.
Question could be that they are prepared that way for safety? just thinking out loud... I think im going to order the Tune DC-14
by kgt on Thu Jun 11, 2015 9:04 am
I 've used 44gr kcnc and token skewers with Campagnolo and Fulcrum wheels. No problem at all.
The only frame that can not 'accept' light skewers is my steel Colnago master. I' ve tried but the rear wheel cannot be secured. No idea why...
Timujin
by Timujin on Thu Jun 11, 2015 9:10 am
kgt wrote:I 've used 44gr kcnc and token skewers with Campagnolo and Fulcrum wheels. No problem at all.
Thanks for the tip, cannot wait to try the wheels this wkd
Timujin
by Timujin on Thu Jun 11, 2015 9:23 am
strobbekoen wrote:strange, the skewers should be more in the 118-122g range.
are you sure your scale was set correctly ?
scales are correct... they display the weights of other parts exact to their manufacturer weights...
GSteg
by GSteg on Thu Jun 11, 2015 4:26 pm
Same here, mine came in around 122g for the set. My old steel ones that I have for my trainers are 180 grams, and these feel lighter.
