Anyone ridden the new campagnolo 2015 bora wheels yet
The valve thing wasn't in all the way. I run veloflex on two sets of the new Boras. They fit fine, but I did push them out the first couple of tries till I got them seated correctly in the rim.
Interesting. @LionelB: are you saying the Veloflex valves will not go through that thing? On both the 50's and 35's I need to use valve extenders. I use Continental extenders. I'll check them with calipers for diameter soon. On my old Boras I know there were certain valve extenders that wouldn't fit but on the new boras there actually seems to be some excess space. ?
sawyer wrote:My Bora One 35 tubulars came in at 1190g ... seems like plenty are coming in way under claimed
to the guys in Vicenza!
hahaha maybe you should edit and name the Romanian city they are based... the guys at Jedi told that was the reason for the big delay as campag moved to Romania...
Timujin wrote:sawyer wrote:My Bora One 35 tubulars came in at 1190g ... seems like plenty are coming in way under claimed
Hi
Campagnolo are based in Vicenza and their R&D (or at least move of it) is done there. They have for some time had a production facility in Romania and have moved more work there this year.
sawyer wrote:Timujin wrote:sawyer wrote:My Bora One 35 tubulars came in at 1190g ... seems like plenty are coming in way under claimed
Hi
indeed that is true... i did place the "hhahaha" before..
Timujin wrote:sawyer wrote:Timujin wrote:sawyer wrote:My Bora One 35 tubulars came in at 1190g ... seems like plenty are coming in way under claimed
Hi
LOL - I know. I'm just being an earnest c0ck-end
My Bora One 35 Tubulars arrived today! (Dark Label)
Underweight at 1158 grams the pair - 664 gr rear (Campagnolo freehub) and 494 gr front I was surprised, I expected them to come overweight like many things do these days.............
I purchased a Shimano freehub model as they were the only Dark Label pair remaining so also purchased a separate Fulcrum Campagnolo freehub body - the rear hub was really heavily lavished in plenty of light bearing grease and the original Shimano body pawls were completely clagged up with the same light grease - made the wheel close to silent in freewheel.
Now deciding which width tyres to fit. I'll be fitting Vittoria CG pave. I have used these for years now as an everyday trainer tyre, not ever scored a puncture (touch wood) I have a pair of the older 24mm wide Pave sitting in the cupboard for over a year now - these fit really snugly into the nice deep rim channel and are a perfect match for the rim width, virtually flush with the brake track margin.
I also have a pair of newer CG Pave coming in the mail......... a 25mm and a 27mm........... decisions, descisions........
I will be moving on from my current Bora Twos to 2 sets of the bora 50's also in tubular - I have a stock pile of 23mm Vittoria Corsa CX tubular tires that I'd like to use versus the hassle of selling and buying 25's (I have great roads here so don't feel the need for 25s either). There were a few earlier posts about the tubular version - and they suggested 23s probably would be ok........does anyone have any long term feedback to reinforce that 23s should run fine on those 24mm rims?
Thanks
Thanks
