130 or 135mm rear spacing on colnago Cx zero disc?
Hi WW.
I tried google, but no luck.
Can any of you tell me if it's 130 or 135mm rear spacing on colnago Cx zero disc?
Current: Colnago CX Zero Di2 Disc, Cannondale F29 carbon3
Previous: Scott Plasma 3 premium, Parlee Z3SL, Parlee Z4, Argon18 E112, TREK TTX7.0, S-Works Transition, Pinarello F4:13
135 is the same spacing as mountinbikes and Cross bikes?
So I can use 29'er wheels?
- spookyload
Most mountain bike hubs at 135 do not come with a freehub for shimano 11 speed. I have found lots of wheel sets I would like to run, but the freehub has to be replaced to accept shimano 11. I can not speak to SRAM, but I know this is the case with Shimano.
I do not mean to steal this thread but I would like to ask a few of you knowledgeable chaps a question. I have a 2015 Specialized Tarmac S-Works Disc. I am pretty sure it is 135 rear spacing. I want to change the stock Roval wheelset for something lighter. Are there any restriction with regards to what hubs I must use??. Some on this forum have suggested that switching the stock rear wheel set will work....... but probably through-off the chain line and rear cassette alaignment.
