Help me clean this wiring up
Yuck.
Your brake cable looks a bit long... you could prob trim a bit of it off.
On my Di2 build I used heat-shrink tubing to sheath both the brake cable and the wire together making it tidy before splitting and entering the two different ports in the frame
If you flipped the little junction box around it looks like all the wires would enter at the front, then you could pair the cable entering the downtube with the brake cable and wrap them or something so that instead of two cables/wires flopping around you'd have one...Sky does something like what I'm talking about:
thanks fo rthe reply, i want to do something asap this is driving me nuts, such a nice build with such a crappy wiring job.
I prefer AG2R's method of attatching the juction box to the rear brake cable and then running the gear cables along the brake cables with some heat shrink/spiral wrap.
- mvacolnago
so clean, I might switch my garmin mount to a barfly, I hate the zip ties around the stem, I will be also replacing the brake cables for Jawire segmented housings
Ltoddokc wrote:Terrible photos but you get the idea. I put the junction under a barfly 2.0 and used heat shrink tubing for the rear brake and di2 wire. Pretty clean look from the side.
AndreLM wrote:You can try to use electrical tape with your current Garmin mount. I have a Barfly for the Powertap Joule, which cannot take zip ties... But with some patience I was able to wrap the Di2 Junction box to the mount.
Im going to try and use velcro that way if I ever need to remove i can do it easily
Thanks , yes i did som eof the trimming last night, It was driving me crazy. Im thinking about doing Jawire Road Pro brake kit , does anyone know if that is Campy compatible? or do i just use the existing cable with the new housing ?
Nice. Once you get it all tidy it'll look really tight.
The shrink wrap is also nice as it prevents the possibility of a cable being snagged and coming unplugged or stretched and damaged...
It's too bad some shops do the bare minimum and don't seem to take much pride in the little details...
showdown wrote:Nice. Once you get it all tidy it'll look really tight.
I agree with you specially with high end builds like this, Im goign to end up reoing a lot things that I tihink could be better.
