Campagnolo bottom bracket adapter for BB91
Westbank
by Westbank
I'm looking at possibly installing a Campagnolo 2015 groupset on a Scott CR1 SL which has a BB91 bottom bracket. I wanted to know what adapter I will need ?
Thanks
bikerjulio
by bikerjulio
Campy make UT specific cups for that application http://www.wiggle.com/campagnolo-ultra-torque-intergrated-oversize-cup-set/
Better pic here http://glorycycles.com/campagnolo-ultra-torque-bottom-bracket-cups-bb86-86-5x41/
UT cranks are Chorus and up. If you are using PT then Campy make the cups for those too.
There's sometimes a buggy.
One.
Valbrona
by Valbrona
BB91=86.5x41mm.
bikerjulio
by bikerjulio
That image is now outdated. Campy make a lot more cups for differing BB "standards" now.
One.
Valbrona
by Valbrona
But the problem with the current Campagnolo Tech Info is that they do not list a BB91, ie. 86.5x41mm option, whereas the older Tech Info did.
Over-Torque™ cups
Uniquely compatible with all the frames on the market:
•Over-Torque™ OS-Fit™ cups BB 386 86,5x46
•Over-Torque™ OS-Fit™ cups BB 30 68x42
•Over-Torque™ OS-Fit™ cups PFBB 30 68x46
•Over-Torque™ OS-Fit™ cups BB 386 86,5x46 ceramic USB
•Over-Torque™ OS-Fit™cups BB 30 68x42 ceramic USB
•Over-Torque™ OS-Fit™ cups PFBB 30 68x46 ceramic USB
•outboard cups Over-Torque™ - BSC
•outboard cups Over-Torque™ - BSC ceramic USB
Taken from here: http://www.campagnolo.com/WW/en/Compone ... orque_cups
jooo
by jooo
They do, you've just linked the wrong page. Over-Torque is for the new 30mm cranksets.
http://www.campagnolo.com/WW/en/Components/ultratorque_cups wrote:Ultra-Torque™ OS-Fit integrated cups 86,5x41
Westbank
by Westbank
Thanks guys ! Much appreciated.
5 8 5
by 5 8 5
Ultra-Torque Cups
BTW, does anyone know why Shimano list BB86 bottom brackets as BB91? Is the shell plus the cups 91mm?
bikerjulio
by bikerjulio
Thanks for posting the current chart @585.
I can only think that in calling it a "BB91" Scott is for some strange reason using the MTB standard name as the name for their road version too. It just adds to all the confusion around BB standards. Or perhaps Shimano has a lock on the "BB86" name? IDK. A more cynical person might just think it's deliberate.
Anyway, on a road frame a BB91 is the same as a BB86. You will notice that 91 is 5mm more than 86, being the extra width of a MTB BB.
One.
jooo
by jooo
'BB91' comes from some of the actual bottom brackets themselves (not frame standards) having BB91 in the part number. It can apply to road or MTB - the '91' doesn't actually reference any size, it's a product hierarchy reference.
bikerjulio
by bikerjulio
Yes I see that now. Still confusing to me why Shimano would invent a BB86 standard and then call the part BB91. Oh well.
One.
743power
Shop Wrench
by 743power
91 probably references the outside width of the assembled bottom bracket cups. The shell is 86.5mm without cups. A Mtb frame with shimano press fit standard is either 89.5 or 92mm, not 91mm.
jooo
by jooo
As I mentioned before, BB91 is taken from a Shimano part number eg: SM-BB91-41B. There are BB91's to suit both road and MTB.
5 8 5
by 5 8 5
Cheers Chaps, Shimano don't make it easy by calling it BB91 when most companies refer to it as BB86.
Bottom bracket standards, gotta love them!
Valbrona
by Valbrona
And the Shimano Press Fit BB 'standard' is more bonkers than the rest because it's not actually a standard at all, in as much as Shimano only make the bottom brackets without giving indication of the size of BB shell that they should go in.
