Dedacciai Ran 2015 frame real vs claimed weight
afnsimoes
by afnsimoes
Dedacciai Ran 2015 frame:
Claimed weight for M size frame: 790 g + Fork: 325 g = 1115 g
Real weight for S size Frame: 895 g + Fork: 374 g = 1269 g (+13,8 %)
I send a mail direct to Dedacciai, and after a long talk, the answer is to return the frame, because they cant assure the frame kit weight.
Please don't make the same mistake that i did.
Dedacciai has a problem with scales...
Gregorio
by Gregorio
I thought it was well known that the Italian manufacturers where the biggest liars of them all concerning weights.
Edit...
That doesn't seem too far off the norm tho. I've seen much worse.
bikerjulio
by bikerjulio
Frame weights are commonly without any hanger, clamps etc, and probably before paint. Those things could easily account for the difference. And the fork would be a lot closer when it's cut.
I'm guessing all frame manufacturers are equally guilty of fudging weights.
There's sometimes a buggy.
One.
tinozee
by tinozee
Did you get a chance to ride that? How was the ride and finish of it? I like the look of the frame.
afnsimoes
by afnsimoes
The frame weight (895g) is without hanger, clamps, etc.
On the Deddacciai web site says:
The result of the RAN frame is very clear: 790 grams of weight for the painted M size and 1.115 grams for the coupled frame and fork of only 325 grams.
No ride yet, i'm still deciding if i'm going to return the frame to the dealer.
wingguy
by wingguy
bikerjulio wrote:I'm guessing all frame manufacturers are equally guilty of fudging weights.
Nope - there are several manufacturers who are pretty spot on all the time. But there are definitely more who aren't. Including almost all Italians :wink:
mike
Resident Pro
by mike
have them give you the lightest from a sample and return that one.
Marin
by Marin
My open mould frame was actually 5 grams lighter than claimed...
Benno
by Benno
What's the consensus on Giants weights? Should I be weighing my Defy Advanced SL frame?
Just think, you are get extra carbon at no charge!
afnsimoes
by afnsimoes
mike wrote:have them give you the lightest from a sample and return that one.
i spoke to other people, the weights are the same...
is just bullshit publicity...
r_mutt
by r_mutt
Yes, all somewhat true about Italian cycling weight but isn't Campagnolo known for frequently weighing less in the real world rather than a published weight?
Even the vaunted Evo when it first came out and astounded everyOne with its strength to weight ratio, no one could quite match what Cannondale claimed. It all depended on the criteria of how each bike company decided to measure weights, and all of them are different aren't they?
@ afnsimoes
Did you ever like this frame? I wonder because if you choose a frame just by its claimed weight why don't you do a better research? Sorry but the way you are attacking Dedacciai sounds somehow suspicious. Ok, you 're pissed off but...
afnsimoes
by afnsimoes
kgt wrote:@ afnsimoes
If i liked this frame? I spend 2100 € on this frame. I think that someone need to like a little to spend that kind of money on a frame.
I did a extensive frame research with several key criteria. The problem it that one of the main key criteria (weight) fails by almost 15%!!!
Somehow suspisious??
If helps, my current bike is a Dedacciai Nero Corsa since 2010...
I purchase a campagnolo bora one 35 wheels. Declared weight 1215g. Real weight 1188 g.
If the real weight was 1382 g. i would "attack" Campagnolo the same way!!!
ToffieBoi
by ToffieBoi
Objects weight much less in Italy, than rest of the world.
