THM Scapula as replacement for Edge 1.0 on a Parlee Z3?
jz4nyc
by jz4nyc
Anyone have specific experience with THM Scapula fork?
Buddy of mine wants to replace his Edge 1.0 on a Parlee Z3 with a Scapula SP.
I dunno if the geo of the Scapula will mess with the sublime feel of the current setup.
Reason is new for the sake of something new, plus lighter weight.
Bike (and fork) is ridden hard, fyi, many many thousands of miles per year of training & racing. Definitely not for a Sunday cafe leisure cruise.
Are THM forks built for abuse or are they more for show & less go?
mike
Resident Pro
by mike
As long as rake is same it should be ok
mike
Resident Pro
by mike
Scapulas are light and strong. No problems whatsoever. Thm are first rate.m
jz4nyc
by jz4nyc
do you have one? can you comment on road "feel" in comparing to what you had prior?
mike
Resident Pro
by mike
I have scapula sp tuned. the lightest one. great all around fork. comfortable, not flexy. I weigh 168 pounds.
jz4nyc
by jz4nyc
cool, thank you.
my friend is about 30 lbs lighter.
mike
Resident Pro
by mike
make sure you get the spina scapula to make the fork transition smoothly into the frame.
jz4nyc
by jz4nyc
thanks i'll mention it to him.
he's getting it thru fairwheel so i presume those guys know what to spec.
mike
Resident Pro
by mike
can't get any better than fairwheel. he is in good hands.
jz4nyc
by jz4nyc
mike after talking w/parlee & fairwheel it turns out the sp is a 44 not a 43. my buddy's gonna pass as there's no interest in changing the handling dynamic there in that regard. lighter & stiffer would be ok, but a geo change, however small, wouldn't be ideal. and it'd be an expensive experiment.
thanks for your feedback though, it's appreciated.
mike
Resident Pro
by mike
no problem!
spdntrxi
by spdntrxi
is the Z3.. tapered head tube ?.. if taper wouldn't you be looking at the THM CT version of the fork ? which is also 44 in rake... I guess if you can source a made by THM for cervelo R5CA or RCA fork... they make 43s for Cervelo.
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
jz4nyc
by jz4nyc
nah it's older z3 (about 10 yrs. old), all round tubes. gorgeous frame.
the current edge 1.0 fork (which is about 4 yrs. old) will be refinished to be good as new.
here's an older photo of the bike, probably 5 years ago. now it has thm m3 cranks, stem's been refinished (all black) and newer sram red stuff.
insanely light bike, but ridden and raced hard for umpteen thousands of miles.
eigner
by eigner
I had the SP tuned on my Parlee Z3 (check signature). I changed to edge 1.0 for, what I felt, was a more stable and predictable riding experience.
Current: Colnago CX Zero Di2 Disc, Cannondale F29 carbon3
Previous: Scott Plasma 3 premium, Parlee Z3SL, Parlee Z4, Argon18 E112, TREK TTX7.0, S-Works Transition, Pinarello F4:13
jz4nyc
by jz4nyc
thanks eigner, that's helpful info. and interesting too. parlee said much the same thing.
