Baller on a budget (groupset advice)
so i blew my budget on a custom frame. that said, i don't want to throw weightweenie'ism aside and throw a bunch of low end parts on it just because, so i'm turning to you guys.
what group would you go for on a budget (say $800 USD max)
assume all are new or close to it... i'm used to the shift mechanism of SRAM, but i'm not averse to switching it up...
I would try to get a force or ultegra for around $600
Ultegra or Chorus if you have a couple hundos more kicking around.
I just got ultegra on my new bike. Biggest compliment i can give it is that you dont know its there. Soo smooth.
Force 22 or even Rival 22.
Ultegra or Chorus, Ultegra is cheaper,(2/3rds the price of Chorus here) easy to set up and easier to find spares for, Chorus is more expensive, harder to set up(but once done correctly that's it) lasts forever and is lighter than Ultegra. I've used Chorus for years and found it faultless, using Ultegra this year but will need to wait a little longer before I can really rate it for durability.
Had this dilemna too a short while ago. Went with force 22 but swapped out a couple of the key components with Red 22 - the chainset and cassette - then you're as close as you can be to the group set weight of Red 22 but a great deal cheaper. Worked for me. Otherwise, best bang for buck is Ultegra 6800.
2014 Parlee Z-Zero DADi2 & ENVE (6.2kg)
2015 Colnago C60 RSWH Campag Chorus & Mavic SLR (c.7kg)
6800 for $600 from Europe is the best deal out there. It's not quite the lightest, but it's functionally as nice as 9000.
I think the Shimano brakes are miles better than anything Sram offers and the Ultegra crankset is unbeatable for the price.
But, if you wanted to use all of your $800 budget, you could get 6800 with a 9000 crankset and shifters.
- btompkins0112
6800
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
