Alloy Tubular wheels - what are you riding?
Wingnut
by Wingnut
The only thing better than alloy tubular wheels is hand built tubular wheels....pre builds coming in was such a downer for higher end cycling imo...
dadoflam08
by dadoflam08
ergott wrote:
dadoflam08 wrote: - by my calcs should be able to bring a wheelset in under 1400g using Sapim Lasers and Race DS.
I forgot if I weighed mine, but I calculate about 1450g. What hubs are you using? My GP4s are around 405g.
I'm planning WI T11's - 32 spoke not 36 so that saves a bit. My wheelbuilder is recommending DT Revolution front and Competition rear which he says will bring the weight in around 1500g(?) - by my calcs will be around 1460g assuming 405g per rim - the Competitions add a bit over a laser/race mix. I can live with 1450g ish given that the rims are relatively light where it counts. 1500g would be a bit higher than I was hoping.
'83 De Rosa+'11 Baum Corretto+'08 BMC Pro Machine >6kg+'86 Pinarello Team +'72 Cinelli SC +'58 Bianchi+'71 Cinelli SC+'78 Masi GC+'83 La Redoute Motobecane+'94 Banesto Pegoretti+'88 Bianchi X4 +'48 Super Elliott+'99 Look Kg281+'18 Pegoretti
mattr
by mattr
Wingnut wrote:The only thing better than alloy tubular wheels is hand built tubular wheels....
didn't think there was anything else.......... ;)
ergott
by ergott
dadoflam08 wrote: 1500g would be a bit higher than I was hoping.
Mine are 32/32
95g front hub
255g rear hub
405g rim
405g rim
360g spokes
6g nipples
My prediction (based on Revo front/Comp rear and alloy nipples)
678g front
863g rear
1541g
Not that I think you should worry about that last 100g. Once you ride them you won't care.
dadoflam08
by dadoflam08
thanks Ergott - I think that is the way I will go. I will post a pic of the final wheels when the new build is ready
