Loose ball ceramic bearings?
mattyNorm
by mattyNorm
More just to do it than because it's necessary but I was wondering if it would be possible to get ceramic bearings to replace the ones in my dura-ace track hubs? Furthermore if there is anything better than the standard dura-ace octalink bb I could use to replace mine as it's worn out.
sungod
by sungod
cs ones are high quality... http://ceramicspeed.com/sport/products/ ... SpeedBalls
low quality ones will certainly be available cheaper
octalink is shimano proprietary, only a few licensed the right to make compatible components, not sure any made a bb, if you want to keep the cranks i'd stick with the da one
eric
by eric
The DA Octalink BB is a good one. It's rebuildable but not sealed as well as sealed bearing BBs. So it does need a rebuild periodically. It's also adjustable, so check that as well.
A track bike that's not ridden in the rain should go a long time between rebuilds.
mattyNorm
by mattyNorm
Mine does get ridden in the rain fairly often. I've heard they are rebuildable but I can't figure out how to open it up and I don't want to just go in hammer a blazing. I'm an experienced mechanic but I've been brought up in the age of pressfit sealed bearings.....
eric
by eric
The rebuild and adjustment instructions are on Shimano's techdocs site: http://si.shimano.com
There also were a couple sealed cartridge bearing versions. The track model may be one of them. The Ultegra one is no longer available.
mattyNorm
by mattyNorm
Thanks guys!!
Rick
by Rick
Also available here: (scroll to bottom of page)
http://www.vcrcbike.com/Individual_Cera ... s_s/36.htm
